Question about Electrolux Washing Machines
It sys the door is open but it is locked
It says the door is open but it is locked. As a result i cannot do anything. I have turneed it off but it has no effect.
  • 520 Answers
The door safety switch has failed. Have it replaced and that should get you back in business. Good luck.
Posted on Nov 13, 2009
Door only opens from the inside
Take out the lock and you will see the rod which slides up and down to connect to make the lock open it may be worn out have it replaced or tie a wire such as a copper wire from unused electrical wires to tighten the gap which may be lose which as a result does not catch properly to open the lock
Sep 16, 2015 | Cars & Trucks
Alarm sounding with remote start and unlocking doors with key fob
If you have an after market alarm sys. take it back to who ever installed it . as far as the key & lock sys . spray some WD40 into the lock and try again . disconect the alarm speaker until you figure it out . Good Luck
Feb 24, 2014 | Cars & Trucks
Washer locked. door lock light blinking. start button light on. won't do anything.
IT IS POSSIBLE YOU HAVE A DEFECTIVE DOOR LOCK OR CONTROL BOARD. CHECK YOU OWNERS MANUAL TOO SEE IF YOUR WASHER HAS A MANUAL RELEASE SO YOU CAN OPEN YOUR DOOR. USUALLY YOU CAN ACCESS A MANUAL RELEASE BY REMOVING THE FRONT BOTTOM PANEL AND REACHING UP UNDER THE DOOR LOCK AND FINDING A PLASTIC PULL PIECE WHICH YOU CALL PULL AND UNLOCK THE DOOR. MAKE SURE YOU UNPLUG THE WASHER FIRST. CHECK THE DOOR LOCK MECHANISMS TO SEE IF ANYTHING IS BROKEN AFTER YOU GET THE DOOR OPEN.
Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
2001 Jeep Cherokee sport. Power door lock won't
Lock and unlock both run off the same power supply...I'd be looking for a bad switch or a broken wire in the door harness where the wires go through the rubber boot between the door and pillar.
Feb 08, 2010 | 2004 Jeep Grand Cherokee
The door button has broken. Is there a way of opening the door
Remove top cover of washer,and see if you can release it from inside the washer, you may have to force the door lock open, so be prepared for the fact that you may damage the door lock as a result of forcing the door open.
Please rate my solution.
Thanks.
Nov 06, 2009 | Candy Washing Machines
The trunk on my 2000 volvo s-40 wont open
you'll need to insert your key into the trunk lock. prior to doing this you'll need to use the automatic lock on the driver side of the vehicle, hit the unluck button twice. Torn the key in the trunk to the left, you may have to slightly press the trunk button in while doing this and give it a lttle wiggle after the key has been turneed to the left push the button all the way in, if this does not work repeat the process but reverse to the right instead of the left.
This manually disables the remote lock for your trunk.
Apr 02, 2009 | 2000 Volvo S40
Security
WITH KEY IN DRIVER'S DOOR LOCK/UNLOCK DOOR TWICE. THIS SHOULD OVERRIDE ALARM SYSTEM. STRONGLY SUGGEST BUYING KEYLESS ENTRY FOB.
Dec 30, 2008 | 1994 Chrysler Concorde
Neptune frontload cloths washer door will not open. the indicater says the door is open and machine will run just a few seconds then shut off. we cannot manually open door. we have turned it off then on...
remove 4 screws under dispenser cover remove trim and cover at front edge of opening is plastic cable pull this should release door sounds like issue with door lock switches
Apr 29, 2008 | Washing Machines
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
