Question about Tools & Hardware - Others
Paslode framing nailer works for about 10 nails and then stops, air comes out from around trigger but it does not fire
  • 44 Answers
Buy a rebuild kit and use it; and in the future oil your gun ( if it's not oiless) and DRAIN YOUR COMPRESSOR DAILY to avoid this problem
Posted on Nov 14, 2009
Paslode 350 Framing nailer trigger does not fire.. Has worked until today, has the correct pressure, but the trigger feels dead.
make sure the safety is not bent what you can try and be careful is remove ALL nails and plug the tool into the air supply, find a small screwdriver and holding the nose up off work use the screwdriver to depress the trigger valve, if it works then you have a safety issue, if not then you have a trigger valve issue. Let me know if you need more help
Jan 18, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Plaslode im250 second fix nail gun fires intermittently. Gas is loading fine and trigger working only fires about one in every ten pulls of trigger
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Dec 31, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode f350s.just replaced all o rings,now when you pull the trigger air leaks out through the trigger,but only when depressed..will not fire nail.please help ..thanks bob
Simple. You have a leak you didn't have before. Either find it, or take it to someone who knows what they're doing. O-rings have a thickness, as well as a diameter. If you used generic rings, that's probably the problem. Use the repair kit by Paslode.
Paslode.com can tell you where your nearest dealer/repairer is.
HH
Dec 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode compact nail. the firing pin will not return
heatman101
Oct 19, 2010 | SK Paslode Sk312 Framing Nailer O`ring...
Quit firing nails motor comes on but nothing happens when pulling trigger
I am assuming that you have changed the gas cylinder. Make sure you have the exact correct cylinder, because there are some that look like they fit, but don't quite seal. This unit requires battery charged for ignition and induction fan. And it requires fuel to drive the nail,.
Oct 16, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
My finish nail guns, 16 ga won't fire.
There is a little plastic piece inside above the trigger...usually this breaks. It touches a microswitch when the cylinder is closed all the way, allowing the nail to fire.
Oct 04, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Nail comes out another hole
are you using the right nails and are they inserted properly if this is an angle gun? Also look for a jammed nail that might be causing this. look at the magazine bolts to make sure they are tight. You can go to Paslode.com for the owners manual and troubleshooting guide.
Sep 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
May 16, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Tools & Hardware - Others Logo
69 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
