Theres a line threw my tv.
Theres a white line that runs across my screen.when the tv worms up the white line muves up and down untill it gets to the middle of the screen,and then all you see is a black screen w/ a white line.the only salution i could find is to hit the tv on the side.this works breifly but the problum dosnt go away.can u help?
  • CMB962490 Jan 11, 2008
    Thanx for the speedy reply.I will try that and let you know if that works. P.S. If someone I know has a problum ill be sure to tell them about your site.THANKS AGAIN.
  • hornbergers Dec 31, 2008
    Tv went to a blank screen with a white horizontal line across the middle. Still has sound.
I Have a tv that has line going side to side
Posted on Jun 16, 2012
  • 579 Answers
It has a problem in the vertical sweep circuit that puts a nonlinearity in its output and you see the glitch in the normally gradual sweep as a line. Since a hit upside the set seems to help, you should just resolder the whole vertical circuit area (doesn't take long) and see if that cures it. If not, start replacing the electrolytic capacitors in that area.
Hope Ya Fix It!
Posted on Jan 08, 2008
I have a 4 in wide white line running threw my screen.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the keyword "line fault" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 17, 2016 | Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
My tv sony kv-xa21m61 display too bright and many horizontal lines. no picture
Vertical retrace lines is the problem. Thin white lines runs across the entire screen, at about an inch apart to each other. Check its video output supply voltage. Reduce the screen voltage to a little bit down and check. If you still wish to know more about this fault, check this site. Pull up older posts there.
Feb 09, 2013 | Sony KV-XA21M61 21" TV
Kid threw remote at screen, lines going across it....
The LCD Screen is damaged beyond repair. Cost to replace TV is cheaper than repair.
May 21, 2010 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
SAmsung has two white lines across screen with no picture
If the 2 white lines are in the centre of the screen it sounds like you have a fault called 'field collapse' . The 'x' or horizontal circuit on the tv deflects the beam across the screen which in your case is ok because the line runs across the screen ok. The 'y' or field circuit on the tv deflects the beam down the screen. Without a circuit diagram for your tv i cannot point to individual components.
Aug 07, 2009 | Samsung Televison & Video
MY TV SCREEN IS JUST A WHITE LINE?
Most likely the screen has permenant damage and is unfixable. if the cable connected to the screen inside the phone was loosened, then you could attempt to fix it by opening up the device and reinsterting the cable, but doing this will void your warrenty.
Jun 26, 2009 | Philips 50PFP5332D 50 in. Plasma...
White lines across TV screeen
if these lines are just at the top of the picture then i would suspect an electrolytic capacitor in the vertical circuit.
May 08, 2008 | Televison & Video
White lines equally spaced 1" apart.
This is probably caused by the small signal board. It controls and decodes the picture information before it is sent to the display panel. It can be fixed by a quailified technician and if you contact philips (this is who makes magnavox) they will tell you the closest certified technician. Hope this helps.
Mar 29, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Televison & Video Logo
393 people viewed this question
Top Televison & Video Experts
