Question about Radio Communications
Laptop my lap top became slow on fully loading c drive with movies..some say computer fstens wen their is a gud free space in c thst true??if so why??
  • 37 Answers
Yes your computer will run faster if you clear up some space on your c drive . The reason for this is the processor can only think fast when there is enough room for processes to be used if you have very little space left it has to search through all thst data to find the thing you want to use ! If you have a DVD burner on your lap top burn the movies to DVD and keep your c drive clear of movies and music they take up more room then most programs If you dont get one or get an external hard drive and keep your movies on that .Hope this helps...Dean
Posted on Feb 01, 2008
This laptop is very slow
Slowness in the laptop can be due to many reasons. You may upgrade your processor( to i5 or i7), but that will be too costly. Try increasing the RAM of your laptop. Also don't overflow your hard drive. Decrease in free space on your hard drive will ultimately slow down your laptop.
Aug 28, 2013 | Computers & Internet
I went to get on my computer and the screen started to load but after the starting page (Averatec my life, my solutions) it went black with a dash flashing in the top left corner and I can't get it to...
sounds like your hard drive became corrupt by virus or malware, or you were very low of disk space. your probably going to have to reformat your hard drive most will say go to system repair when you reinstall windows, but I always feel a full format is the safest way, because repairing your pc will not remove the virus vs. formatting
Jun 04, 2011 | Averatec AllInOne A2 Desktop
I have a Fanner SPIRE Aluminium Gigapod External 3.5" external hard drive linked to my Windows XP laptop but the link up between the two has recently become increasingly slower as has the response of the...
The hard disk inside that Spire case has died - running the free space clean from CCleaner (a very intensive procedure) has been the death blow to an already sick disk.. Nothing more can be done to save it and the data on it. Replace it with a new one.
Jul 17, 2010 | Fanner SPIRE Aluminium GigaPod External...
Ibm thinkpad t41,its processing slow what could be the problem and it has a lot of hard drive space left.
Available RAM is more important for speeding up your laptop than available hard drive space. Check your available RAM by:
  1. Starting the Task Manager (Right click on taskbar and select it)
  2. Select the Performance Tab
  3. Compare the Physical Memory vs Commit Charge numbers.
For example, my fast computer has 3600 megs of total physical memory compared to a commit charge of 1200 megs. Meanwhile, my older, slow computer has only 650 megs of total physical memory with a commit charge of 1400 megs. This means the slow computer is always making 'pretend' memory from hard drive space, and that is why it is so slow. This is most likely the case with your computer as well.
I hope that helps.
Jul 14, 2010 | IBM ThinkPad T41 Notebook
Install error
How much free,disk space do you have on your hard drive? The Clickart program requires enough space to properly install. Hope this helps. Bud
Jan 22, 2009 | Findex ClickArt Christian Publishing Suite...
My lap top is extremely slow whenever i am doing anything online
uninstall unwanted software click start> control panel> Add/Remove programs
Delete junk files
1. Click run start> Run> type %temp%
2. Click run start> Run> type temp
Restart computer.
GooD Luck !
Dec 08, 2008 | Sharp Actius AL27 Notebook
Abt crash dump
To recover your files you will need a 2.5" external sata usb hard drive case. Take the hard drive out of your lap top and install it in the case. Plug the USB drive into another computer with enough space to copy all the files you want to save. Once you have all the files backed up that you need format the drive and re install your operating system fresh. Then load all your rescued files back to your laptop with another external USB backup drive. This is the only way and I know it works because I have to do it every time I thrash my laptop running bad cracks. Please take the time to rate this fixya for sharing my secrets for free. If you need more help feel free to ask.
Apr 04, 2008 | HP Compaq Presario C500t Notebook
Toshiba Lap Top Model #PSAA2U-04E018
sounds really bad. hard drive crash scene most likely. You might want to boot from install disk to see if the rest of the machine is happy or not.
Feb 05, 2008 | Computers & Internet
Yes. With a typical default configuration you should keep an amount of disk space free on the C: drive as this is where your virtual memory or page file sits. When the computers ram fills up, the OS writes some of that memory to disk (virtual memory) so that it can free up real hardware memory (which is fast) for running apps. When disk space is restricted on the C: drive memory management becomes more innefficient as things need to be erased from memory and then reloaded rather than just swapped from the virtual memory on the disk. Worse than slowness if you completely run out of space your system will freeze up.
You should make sure your c: drive does not fill up. Also if you have another drive (such as a d:drive) with more space you can change where the virtual memory resides and place it there so that it can grow as it needs to.
Jan 08, 2008 | Audio Players & Recorders
ACER 1360
Unless I am mistaken, the D drive or partition is the partition that contains the restore feature for yor laptop. This may or may not be hidden system files. As far as the available free space on your C drive, you WILL need to either delete files and/or backup and delete files. Image files, music files, cookies temp files take up a lot of disk space. Try this and I think you will find more free space. BPCS
Dec 23, 2007 | Acer Aspire 1360 Notebook
Radio Communications Logo
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
