Question about Casio Parts Cash Register PC Desktop
Setting Date and Time is driving me nuts! I've tried "variations on a theme," as well as exactly following instructions. The Date and Time will set, but not change over time. Still shows time and date it was initially set. HELP!
  • bnf_bcs Nov 13, 2009
    Thank you for prior reply.
    Although the first 2 lines of your instructions were different, results are same.
    The date and time will not be remembered.
    Should programming be saved to FLASH, #1=Yes, #2=No. ??
    Thank you.
    Robert
  • Casio Master
  • 4,924 Answers
Yes ..indeed you have to save the programing to Flash ...in order to work and be remembered...the flash is similar to the bios in computers ..the place were the time and date is remembered and has a power of its own ..and work even if its shut down ..
Posted on Nov 14, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To set date follow these steps-
Turn PGM key to PGM position
Press 1
Press the Subtotal key
Enter the date as 6 digits in sequence Year/Month/Day
November 14, 2009 as 11 14 09
Press the X/Date Time key
Press the C key
To set the time follow these steps—
Press 1
Enter the time using 24-hour format. Example: 8:30 am as 0830
8:30 PM as 2030
Press the X/ Date Time key
Press the C key
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 13, 2009
  • Rylee Smith
    Rylee Smith Nov 14, 2009
    Hi Robert,
    You are right it should be saved to #1=Yes.
    Thanks
    Rylee
How do i set the time on a pantech p5000?
Date and Time Settings Pantech Marauder
Date and Time Settings - Pantech Marauder™ [Device-Specific Instructions]
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Nov 01, 2015 | Pantech Cell Phones
Setting date on Staples SPL-P500 calculator
You press TIME and then you have a button = (it's also written SET on it) press for few second, it will flash, you can now set the date, DD-MM-YYYY than =/SET than TIME again then, =/SET you can now set the time ( the button X / AM-PM to set am or pm) you press =/SET when you're done, and you're set !
Oct 22, 2012 | Staples SPLP500 Scientific Calculator
To set date and time on answering machine of a vtech cordless phone
Now that you've finally gotten around to specifying the model of your phone, follow the instruction on page 14 of the CS6429-3 manual.
Sep 14, 2012 | Vtech DECT 6.0 Cordless Phone with Digital...
I am not able to correct the month in the date setting on my SkyHawk. I've set the watch on cal in receive mode then closed the crown. I then push and hold the lower button for two seconds waiting...
If your watch is still out of whack, please consider reviewong the instructions here: http://www.citizenwatch.com/
If you still cant get it to go, Citizen offers a very reasonably priced repair service.
May 23, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
How do I set the date and time spamp on a Canon A490
Hello and Welcome to FixYa!
To set the date and time stamp on pictures, Follow the given instructions:
Setting Date and Time:
First of all set the exact and time if your camera:
  • Press the "Menu" button on the camera and use the right navigation button to choose the "Set Up" menu.
  • Scroll down to "Date/Time" and press the ""Func./Set" button. The set date and time will appear on the screen, and the month unit will flash.
  • Adjust the month unit by pressing the up or down navigation buttons. Move to the day unit by pressing the right navigation button. Use the same instructions to adjust each unit of the date and time.Push the "Func./Set" button to save the time and date settings.
Setting Date Stamp on pictures:
  • Press the "Func./Set" button and select "Recording Pixels" and "Postcard". The camera is now set to "Postcard" mode.
  • Open the "Rec." menu by pressing the "Menu" button on the back of the camera.
  • Highlight "Date Stamp" by pressing the down navigation button.
  • Change the "Date Stamp" setting by pressing the right or left navigation button. Your choices are "Off", "Date" or "Date/Time". Now, when you take photographs the date or the date and time will appear on the picture.
If this solution helps you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
Thanks you for using FixYa!
Apr 11, 2011 | Canon PowerShot A490 Digital Camera
Unable to install anything on my e63, especially themes
The errors are caused because of the security measures introduced into the new version of Symbian Series 60 mobile operating system disallowing installation of old applications and invalid certificates, however bypassing this security feature and fixing these certificate errors to install themes and softwares is very easy, simply follow the instructions below:
  1. Open you mobile main Menu.
  2. Navigate to Settings -> General -> Date and time
  3. Now change the year back one year.
  4. Now install the application.
  5. Don't forget to change date back to original.
If the above does not solve the problem goto Application Manager > Options > Settings and set "Online Certificate check" = Off and Software Installation = All.
Mar 20, 2011 | Nokia E63 Cell Phone
Hello my mobil have a problem when i install themes it is not installing certificat error
  5. Now install the application.
  6. Don't forget to change date back to original.
Mar 18, 2011 | Nokia E63 Cell Phone
How to install .sis theme on nokia 5233, it gives me certification error
when receiving a certificate error on installing .sis file, try to set the date on your cellphone at an eralier time, say 01/01/2007..
Jan 31, 2011 | Nokia Cell Phones
My e 63 isnt supporting themes which are being downloaded from the following web sites example zedge and symbian web site
Don't worry this is simple settings issue.
Note:Please download only E63 series Themes only.......not other phone themes...
To solve this problem follow the steps:
1)Go to Menu-> Tools-> Application Manager
2) Then press (options) button, select (settings)
3) Make sure <Software installation > is set to "All" and < Online certif.check > is set to "Off"
Some time you get certificate expire to solve this you have to change the date.This is to prevent the users from using expired application:
If you encounter Expired Certificate error during installation, please set your phone date to 03/03/2007 before installion of the theme .You can reset your phone date back after installation.
If still the problem persist Change the PC date also because it will get synchronized with your mobile and try different dates so that it will match the application date.(Reason is every application is valid for a period of time
example.from 03/03/2007 to 03/09/2007 so you have to give date between this.So try old dates usually some years back...
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 31, 2010 | Nokia E63 Cell Phone
Set Date
Use the time set key (M+)
Jan 20, 2008 | Canon Office Equipment & Supplies
Casio Parts Cash Register PC Desktop Logo
35 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
