Question about E-Machines eMachines Desktop PC
I NEED TO CONNECT AN ETHERNET CABLE FOR WIRELESS CONNECTION.CANNOT FIND A SUITABLE PORT!
    Novelist:
  • 154 Answers
Your computer should come equiped with an ethernet port. If it does not then you can get a male/female ended ethernet cable connector which can plug one end into USB and the other into an ethernet port.
Posted on Nov 14, 2009
Will a standard b,g,n wireless usb adapter work on an NEC projector?
No. The projector isn't a computer. It can't download drivers and software to make 3rd party devices work.
Use a wireless bridge and connect to the projector's Ethernet port if it has one suitable for network display. Otherwise stick with a cable connection from a laptop
Sep 02, 2014 | Office Equipment & Supplies
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
I have two computers in the house which are linked by an ethernet cables, my wireless router only has one ethernet hole,so I would like to know what I need to buy? such as an adapter or something, so I can...
If there is only 1 ethernet port on your router it sounds like this is the port for your modem to connect to your router and that your router is only built for wireless. If you want to connect computers via ethernet cable you will need either a new router with a 4 port switch or a new wireless router with a 4 port switch. (you can get more than 4 ports if you have more that 4 computers).
Mar 03, 2011 | Office Equipment & Supplies
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
I have this router Belkin G Router Model :
belkin routers are compatible with all ISPs.... all that it requires is an ethernet cable that should come from ISP, either directly or through modem... so if your virgin connection gives you an ethernet port in their modem, you can configure the belkin router accordingly...
Apr 07, 2010 | Belkin Wireless G Router
I am trying to connect my new router to my laptop,but the instructions say i should connect my pc to the internet by connecting my ethernet cable to the router.my problem is i have only one connection and...
Modem <-- Ethernet cable --> WAN port on router
LAN port #1 on router <--- Ethernet cable --> network-port on desktop computer
LAN port #2 on router <-- Ethernet cable --> network-port on laptop computer
If the router has built-in "wireless" capability, then use the desktop computer's connection to the router to "configure" the wireless adapter, i.e., pick an SSID, and establish a password, and then your laptop computer can use the SSID/password to connect "wirelessly" to the router.
Mar 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
I DON'T KNOW WHERE TO PUT WHAT WIRE TO CONNECT 2 COMPUTERS
You connect the phone line to the router, then you connect ONE PC to the router via an Ethernet cable and configure router, after that you can remove that Ethernet connection and connect wirelessly.
Feb 10, 2010 | D-Link AirPlus DI-524 Wireless Router
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
E-Machines eMachines Desktop PC Logo
63 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
