Question about Logitech Z-5500 Computer Speakers
I have no sound from one of the speakers on my Z-2300 . The speaker itself isn't the problem. I swithced the wires on the back of he sub woofer and both speakers worked when I plugged them into the left port, and neither of them worked when I plugged them into the right port. Is this something I can fix?
  • 460 Answers
Probably not, seems the output ic or transisters are blown in the right channel. take it to a service shop. also see if under warranty, if you bought it new within the past year. it will be fixed or replaced..good luck...
Posted on Nov 13, 2009
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
No left side output to speaker
Check the line in jack. Often it will be somewhat damaged and provide only mono output. Check the connection between the sub woofer and the speakers as well. Wiggle it around while sound is playing. Report back with any information!
Mar 06, 2011 | Logitech Z-2300 Computer Speakers
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
I have a JBL TLX CSS-SUB1 sub at the back are where you connect the speaker wires to the receiver but i don't know witch wire goes in what? i have no clue
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | JBL Audio Players & Recorders
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
I need a replacement for my logitech z-2300 speaker wired remote control. How and where can I get one?
To the two people with problems. This sounds a bit odd, but do you still have the broken remotes? I'm looking for a broken one. I'd pay shipping and throw a few bucks your way if you could send it to me.
AIM: gonzoleben
Email: andywitzz [at] gmail [dot] com
Thanks!
-Andrew
Apr 14, 2009 | Logitech Z-2300 Computer Speakers
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Logitech Z-2300 computer speakers
Please recheck the connection of subwoffer once again..
thankyou...
Jan 02, 2008 | Logitech Z-2300 Computer Speakers
No sound out of woofer
Hello sparkie102
Happy Holidays
you have to check if all the cables are well connected, and in the right inputs. 2) check your software for sound that is enable, fine.
turn up the sub volume , if got it independent.
other that this, is a failure sub. if got warranty, use it! or RMS your sub.
Dec 26, 2007 | Logitech Z-2300 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
436 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
