Need technical support to hook up this machine.
    Top Expert:
  • Office Equip... Master
  • 75,797 Answers
Please explain what u are doing, u give no useful info to help u. thanks
Posted on Nov 13, 2009
Sony walkman NWZ E383/RC
you need to install latest Windows media player.
Sony devices have been technically hooked with Windows media player for all windows machines.
Jul 14, 2014 | Sony Walkman Audio Players & Recorders
Timing Lag.
Are you sure the timing has gone,?
Check these first, needle in the correct way round, threaded properly, needle not blunt or bent.
If the machine still misses stitches arfter checking this then it needs retiming, select straight stitch, take off the needle plate, take out the bobbin case if you have a seperate bobbin case, and undo the two clips to take off the race cover, if you have a drop in bobbin just take out the bobbin, take the bottom off the machine so you can see underneath the raceway, tilt the machine back it will be easier, turn the balance wheel by hand towards you so the needle is going down into the machine then on its way back up, just as it starts to go up stop, look at the point of the hook, it should be just above the eye of the needle, if it is not undo the screws on the vertical gear underneath the raceway and you can move the hook round to where it should be, tighten and put the plate and parts back and test sew, if you have a front loading bobbin case undo the screws on the shaft of the raceway and move the hook round to where it should be, it may take you several attempts, if the machine sews perfectly on straight stitch test it on wide zig zag, if it misses stitches one side you will have to start again moving the hook either side slightly until you get it right thx nick
Feb 01, 2008 | Bernina Virtuosa 160
I HAVE A BSR 3000 EQ, A TECHNICS POWER AMP SE-9021K,AND A TECHNICS SU-9011K PRE AMP HOW DO I HOOK IT ALL UP?
Very easy.
SOURCE > PRE-AMP > EQUALIZER > POWER AMP.
Not sure why you want to do it, though. Your pre-amp already has an abundance of sophisticated tone controls and filters.
If I might venture a guess, you are trying to correct some serious deficit in your speakers or in your source. If you need sophisticated tone controls, filters, AND an equalizer, you need to ask yourself why ... and fix that problem.
Oct 12, 2012 | Audio Players & Recorders
Sewing machine
The top thread is probably breaking due to the bobbin thread tangling.
First-off fit a new needle .... do that anyway ! And if you haven't recently cleaned your machine (and you should do it every week as a minimum), clean-out under the stitch plate, remove the hook, clean the hook race and give it a small drop of oil, even if you're using the lightweight plastic hook/shuttle. Check that you have adequate bobbin tension ... when you pull the thread out of the bobbin case there should be a bit of resistance --- technically, this should be set-up using the correct tool and a set of weights, but if there is no, or very little resistance, you need to increase the bobbin tension a little bit at a time using the small screw that holds the tension spring down onto the bobbin case. This is a very fine adjustment, so you may find you only need to turn the screw less than a quarter turn to get it right. Ensure that, when you thread the top thread up, you do-so with the foot lifted so that the thread goes down properly between the top tension discs.If you're still not getting anywhere, check the basic timing/needle depth by looking at some of my other posts on the subject.
Nov 26, 2011 | Bernina Activa 140
I have a Pioneer VSX-520 receiver and was told I need a pre-amp to hook up my record player.I purchased a technics integrated power amplifier from a flea market and was wondering if it is compatible with...
IF the unidentified new Technics Integrated Amp has a PHONO section it will support the turntable.
IF the unidentified new Technics Integrated Amp has, say, a Tape Output, that could feed any Line Level input on the Pioneer. OUT to IN.
Aug 07, 2011 | Pioneer Audio Players & Recorders
Need a manual for Technics Receiver SA-160
Go and google it as you can buy it on line ... how tough can it be the hook up speaker wires? The small speakers are front and back, left and right in pairs. red wire to red jack on back , black wire to black jack. big speaker goes to sub wolf. jack in back. Now get those wires and play your Christmas music. note jacks may be marked fr fl rr rl sub
Dec 10, 2009 | Audio Players & Recorders
Can't get machine to pull up bobbin thread
This is a hook/needle timing issue. It will need to be adjusted by an authorized Husqvarna Viking dealer or they can send to Husqvarna Viking (SVP) Technical Service Dept in Tennessee for them to do the repair. A list of authorized dealers is available at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Apr 17, 2009 | Husqvarna Viking 1
Problem: The needle threader does not line up with needle eye
Tr
Machines Support
For questions regarding Machine Support, fill out the Machines Support Form or call anytime, Monday through Friday 8:30AM – 5:00PM EST, 1-800-631-0183, ext. 774.
Technical Support
For questions regarding Technical Support, installing, updating, or using your embroidery software, fill out the Software Support Form or call anytime, Monday through Friday 8:30AM – 5:00PM EST, 1-800-631-0183, ext. 775.
General Inquiries
For general questions, please use the General Inquiries Form.
Request a Machine BrochureFill out the Brochure Request Form to request a brochure for your choice of machine.
Janome Mailing List
Click here to join the Janome Mailing List.
y this:
Mar 20, 2009 | Janome 6019QC Mechanical Sewing Machine
Hooking up audio components
This was answered here: http://www.fixya.com/support/t1371668-having_hard_time_connecting_various
- OPTiC
http://www.djproaudio.com
http://www.repairny.com
Dec 13, 2008 | Technics Audio Players & Recorders
14 people viewed this question
k24674
