Question about Audiovox Bosch 718 World Cellular Phone
When do you know when the freezeer has reached its optimum tempreture. We have a bosch exxcel freezer GSE28423GB
Instruction manual for bosch exxcel dishwasher
Hello hazenchris
Please click the link below to download the user manual for the Bosch SRS45E02GB/18.
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=qcbpLlccdcso0pdmdb---03K&UMOBID=qcbpLnecdcso0pdmdb---03K
You will need to have Adobe Reader or another PDF file viewer installed on your PC to view the manual:
http://get.adobe.com/uk/reader/
If you need assistance with your Bosch dishwasher, please let me know.
Regards,
BElectric
Oct 17, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Ive forgotten which way the dial goes...is it min or max to make the fridge cold? the freezer part is working however
on any refrigerator or freezer it should be set in the middle whereas if your unit said 0-9 you would set your unit to 5 or if it just says min and max in between these would be the the best. optimum tempretures are at 37-38 in your refrigerator and 0 in your freezer if you have any further questions message me back and please remember to rank how this opinion has helped it allows for me to help others in similar situations Thanks Rick
p.s it is also best to keep two manual thermometers in both the freezer and the refrigerator at all times this way you always know your exact tempreture
Mar 20, 2011 | Refrigerators
Have taken delivery of a GENERAL ELECTRIC,S 442 G E.. Fridge area after 24hrs can not adjust dial to coldest will move dial past coldest no change in tempreture at present 1-10 only 5.. Kind Regards...
tempreture inside freezer should be at 0 inside fridge would be 38 these are both optimum tempretures if you just received delivery there is no sense in you researching how to fix or taking anything apart it is warrantied and if you were to try to fix the unit you would void your warranty best thing to do is call them monday morning Thanks again Rick
p.s if you have any further questions message me back and please remember when our chat has concluded to rank how this opinion has helped
Jan 09, 2011 | GE Refrigerators
Bosch exxel fridge freezer should the light go dim when the door is shut and not off completely
the light should go OFF when the door is shut.(that is if ive read your question correctly).
Dec 18, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
There is a buildup of ice behind the lower section of the plastic back panel which eventually prevents the door from closing.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
How to take doors off Bosch Exxcel KGH39A07GB
I've just had to do this - a real pain, and you would think that Bosch would include it in the instructions or somewhere on their website!
You have to put the fridge/freezer on its back (putting a cushion or something like that at the top to make sure the back doesn't get damanged). Starting at the bottom, unscrew the three bolts holding the bottom door in place, then the middle hinge between the fridge and freezer, and then the screws at the top holding the fridge door in place. Then reverse everything round (you may have to make holes where there are dimples on the top of the freezer door/bottom of the fridge door). Good luck!
Sep 19, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
Hi can you tell me what the red explanation mark on my bosch exxcel frost free version fridge means please. mike
it has a problem and its telling you this,,,most likely its to warm inside of it this could be the thermostat playing up
Jul 04, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
Bosch exxcel fridge freezer - freezer not working properly only reaching -10 when set on maximum
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 27, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Dodgy fridge light
Generally, these doors drop from excessive weight, a warn part or loose fittings. Unload the door and investigate. You may also want to check that the unit is levelled...the box may be warping/sagging...although this is unlikely.
Dec 24, 2007 | Bosch Exxcel KGV35421 Bottom Freezer...
Audiovox Bosch 718 World Cellular Phone Logo
52 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
