Question about Zanussi ZEBF250W Bottom Freezer Refrigerator
Power light flashing on & off
The power light on my ZEBF250W Zanussi fridge freezer intermittently flashes on & off. It can be cleared by powering the unit off & back on again.
The fridge freezer still seem to work OK apart from this. What might be wrong with it?
  • Keith1953 Jan 08, 2008
    It is definately not frosted up, I have tried powering off (but not unplugging it ) beffore. It only cures it for a while, then it starts flashing again. How can I interpret this error code?
  • Anonymous Mar 16, 2014
    The freezer is not working and the green light is flashing inside the fridge.
  • 236 Answers
Try to unplug and plug the power cord this may help, flashes is an error code. Try also the defrosting, error codes alarm the owner if there are some abnormal operation int the unit.
Posted on Jan 08, 2008
Sounds like a bad solder joint causing intermittent power issues...
Jun 19, 2016 | Zanussi Refrigerators
Model zx97/5si fridge freezer. Why are the interior light and compressor not working?
My question is whether these three LEDs steady light or flashing during normal mode?
25836454-ucy4wx0s13wzivwce2sy2wdr-4-0.jpg If all three LEDs flash, that means NTC sensors failure!
NTC evaporator sensor is placed on back side of battery evaporator and NTC ambient sensor is placed on front side of batery evaporator.
Battery evaporator is placed in freezer compartment.
Dado
Aug 25, 2015 | Zanussi Refrigerators
Zanussi fridge freezer fan sticking
See the picture below:
It is best to perform a visual inspection of the fan and measure the winding resistance. In this case there is no possibility of blocking the fan due to the excessive amount of ice. The reason is clearly visible from the the picture. The fan is located above the battery evaporator.
So, could be faulty: fun, wiring between fun and PCB, printed circuit board (PCB).
Dado
May 04, 2014 | Zanussi ZEBF250W Bottom Freezer...
Can i turn the freezer part of my fridge of so i can defrost the bottom part n leave the top part on , i have a zanussi electrolux
no your model is a single compressor which runs both frdge and freezer.. freezer is supposed to be frost free however freezing elements can be overwhelmed with frost if door has been left open. there is a drain hole behind the back panel of the freezer that can block or freeze up causing water to flow in tp the freezer and turn to ice. complete defrost and check that drain hole is clear to fix it.
Jul 24, 2010 | Zanussi ZEBF250W Bottom Freezer...
Fridge does not cool
lo1972
Sounds like ice built up on the evaporator coils inside the freezer. thus hindering air flow to the refridgerator section. Is there ice build up in the freezer? This is assuming the temperature control didn't get changed inadverttily.
Hope this helps
handiman518
Jan 16, 2008 | Zanussi ZEBF250W Bottom Freezer...
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Zanussi ZEBF250W Bottom Freezer Refrigerator Logo
602 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
