Question about HP OfficeJet 4315 All-In-One InkJet Printer
When i place paper in printer and push scan---it says no scan options.
    President:
  • 2,306 Answers
The scan options are in your computer. You need HP scanning software installed and running and of course you must be connected to your computer.
Posted on Nov 13, 2009
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: scanning
Hi old novii, sorry to but in but I had bigmountain on chat.
Hi again Bigmountain, pls download the patch here. If that still does not work uninstall as we have discussed and download/install the new drivers/installers here. So even if your CD is not working, it should still go through with the installation. Please, pls follow installations/on screen instructions.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 14, 2008
  • 5103 Answers
SOURCE: how do I set scan option
Look at this URL: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=57769 for details
The scan options will depend on which version of Vista you are running. Since the Home Premium version is the most common, I'd suggest you look for Windows Photo Gallery or Paint and then under File look for the Import from Scanner or From Scanner (depending on the program).
This will work if your computer is directly connected to the scanner. If you have a router or print server that let you network your All-in-One, you need to look at the specifics for that product.
I hope this helps.
Printer eror code U051
Instructions
    • 1
      Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
    • 2
      Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
    • 3
      Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
    • 4
      Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
    • 5
      Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
    • 6
      Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
    • 7
      Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
Mar 07, 2012 | Canon MX700 Office All-In-One InkJet...
Code error 5100
  • 1.
  • Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
  • 2 Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
  • 3 Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
  • 4 Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
  • 5 Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
  • 6 Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
  • 7 Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
May 20, 2011 | Canon Office Equipment & Supplies
How to fix error code 5100 for canon ip6320D. it appearing while head cleaning.
This is either due to a physical error caused by a paper jam, or incorrectly seated ink. To fix:
Jan 21, 2011 | Canon Office Equipment & Supplies
Message says no paper in front tray. Paper is where I've always put it in back. Won't print.
go print -> properties -> page setup -> print options -> tick Disable the paper source setting of the application software -> hit ok and go back to "main" -> select the paper source that you want and hit ok ok and print
Nov 20, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I received error code 5100.
  • Check the paper feed tray on the front end of the Canon to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
  • Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
  • Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
  • Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
  • Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated
  • Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again
  • Oct 11, 2010 | Canon Office Equipment & Supplies
    CAn't scan legal paper to pdf it comes up with half the page scanned?
    Go to setup on scanner. There is a place to change the size of paper.
    Nov 30, 2009 | Brother MFC-7820N Printer
    How to work scanner
    Lift Scanner Lid. Place item to be scanned on glass surface/close lid.
    Press Scan Menu Button
    Make Choice Push Start.
    Make sure you have paper in tray.
    Nov 15, 2009 | HP Officejet 4315 All-in-One Printer
    No scan options How can I get it to scan?
    if you really want the scant option on your computer, u have to reinstall the printer driver as in full installation, but if not or if it does not still work, make sure the documents are placed in the right feeder and the papers in the correct feeder, then on your printer press the scan botton it will surelly print. thanks
    Jul 17, 2009 | HP Officejet 4315v All-In-One InkJet...
    My ADF Scan does not detect a sheet of paper in feed tray. When I push scan I get a nothing in the ADF. Is there a reset or diagnostic to work with? Scan from platen works fine. Gary
    There is a small black lever toward the rear where you place the documents to scan. if it is broken or missing it can't see when you place a paper there to scan. If you can see a rectangular hole in that area with nothing in it, you will have to take apart to find and replace the sensor lever.
    Jun 30, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Scan and e-mail
    hi..place the paper in the printer,then go
    to printer setting ,there u will get a option
    for scan.Select that option and click ok.
    It starts scanning,then it asks where to save
    the scanned paper.you choose your location.
    Then u can e-mail it as u do.
    thank u..
    Feb 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
    HP OfficeJet 4315 All-In-One InkJet Printer Logo
    125 people viewed this question
    Seeker5211
    Seeker5211
