Question about Rancilio Silvia Espresso Machine
Our Rancilio Silvia is producing really bad tasting coffee of late...my husband thinks that it is old water but I think it may have something to do with the fact that it has been leaking from the steam wand. Maybe an old seal is melting and creating this flavour or maybe it needs a serious internal cleaning?
Hi cstanphi,
Bancheracer is very likely to be right!
I never have to clean my screen this way. Every time I brew coffee, I pump a half cup of water trough the empty filter, simultanousely with grinding the beens.
This keeps the filter as well as the brew head screen permanently clean very easely, but quite important; it ensures that the brew head and the filter got the right temperture, when I brew the coffee.
The machine heat the water to 93 deg. C, which is the right temperture for brewing, butfilter wont keep this temperture, when not used for a while. Therefore the temperture will fall by its way through the filter, which makes the coffee less creamy and more bitter.
So the procedure is:
  1. Empty the filter
  2. Attach the filter in the brew head
  3. Push the upper butter button
  4. Grind the coffee beens
  5. Let the machine pump water, and the big orange lamp turns on.
  6. Turn off the pump, when the lamp has been turned on for ~3 seconds.
  7. Detach the filter immediately and dry it with a tissue.
  8. Fill in and tamp the coffee, when the filter is still hot.
  9. Attach the filter and brew the coffee quite after the lamp is turned off.
Perhaps you will notice, that the coffee comes out much more creamy than it used to, whithout this procedure.
- And you never have to clean the screen and the filter ;-)
Enjoy!
Posted on Dec 05, 2009
  • 1,089 Answers
Hi
More than likely its you brew head screen. Coffee will build up on the top surface and turn rancid after awhile. Remove the screen(its either a screw or bolt that holds it on). I like to remove everything and turn the machine upside down on a towel. That way I can see what I am doing. Clean everything even around the brew head gasket. This gasket needs to changed every year for best sealing of the portafilter. Buy 2 because they always fail on Friday when you have a party on Saturday.
Soak you brew head screen in hot water with a pinch of automatic dish washing detergent or espresso machine cleaner. Use a tooth brush to remove the crusty burnt on coffee residue or just buy a new screen. Clean this screen every 6 months because they should last the life of the machine.
Posted on Nov 13, 2009
I own a Rancillo classe 10, how do you reset volume of water going through head.
Regards Tony
Posted on Aug 13, 2010
4 Suggested Answers
unclebuck521
SOURCE: water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Posted on Feb 03, 2009
z34aga
  • 137 Answers
SOURCE: leaking steam valve rancilio miss audrey
you should take out the knob first, than you try to disasembke the SHAFT of valve from the valve body, in this types(small espresso coffe machines) usualy producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal vorkery where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine.
ps: notice you only polish the SHAFT , dont let them to short the more than 0.5 mm
Posted on Apr 02, 2009
EsWorld
  • 1618 Answers
SOURCE: Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Posted on Jan 21, 2010
Brewer shooting steam instead of water in Rancilio silvia
Machine may be full of limescale and pipes are blocked... Do you know if the water in the area is Hard? Maybe it needs a descale cycle, although it may be too late for this. May need to open it up and clean out the boiler manually.
Feb 23, 2013 | Rancilio Silvia Espresso Machine
My Rancilio Silvia, about three years old, does not seem to be generating sufficient pressure. Standard espresso grind requires about two minutes for a shot and coffee is bitter. Is there any way to...
First things first, remove the screw and shower in the head and clean. Then change grind to something a little coarser, since we are testing the machine we will not tamp the coffee(we are doing this to have a constant in our coffee brewing equation). Note how long it took to brew, if it brewed longer than 40 secs, then adjust grind and try again. If coffee shots looks better and taste better then we are on the right track, we are looking for any thing between 15 and 30 sec depending on the coffee blend from light to dark. If you are getting the same results over 40 secs for a shot no matter what grind you use then the pump needs to be replaced.
Nov 28, 2010 | Rancilio Silvia Espresso Machine
My Rancilio Silvia developed a terrible burning smell. The water still comes out of the steaming wand. I have only been using the steaming wand for the last month and not the espresso maker. I have been...
Sounds like the machine needs to be descaled and the boiler and element needs to be checked.
Was the machine left on for a long time?
If yes then the element needs to be replaced.
Feb 20, 2010 | Rancilio Silvia Espresso Machine
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Leaking between base stand and body
You are correct. There might be something keeping the solenoid from closing. Yes you husband should be able to fix it. Have him clean out the solenoid.
Sep 28, 2009 | Rancilio Silvia Espresso Machine
Hot water only with the the setam switch on
The only thing I can think of at this moment is that one of the 3 thermostats are not functioning, use your ohms meter and check them out.
May 17, 2009 | Rancilio Silvia Espresso Machine
Rancilio producing very very slow shots...even when no portafilter.
from your description i can conclude only 2 things:
  1. coffe grinded too fine
  2. pump pressure low
i think you can chek these 2 and have your perfect espresso again
Jan 19, 2008 | Rancilio SILVIAespresso&cappuccino machine
Silvia
there are two class of expresso coffée: one produce crema and the other none. A 9 sec shot, means you are putting ground coffee that are way too coarse. The Silvia requires coffee grounf extremely fine, near powder texture.
Hope this help
Dec 28, 2007 | Rancilio SILVIAespresso&cappuccino machine
Rancilio Silvia Espresso Machine Logo
333 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
