Question about Intel Pro PC Camera CS430 Webcam
Won't connect to my PC. Was working fine. The PC is seeing something plugged in but it doesn't know what it is.
    Sergeant:
  • 267 Answers
Try uninstalling it and reinstalling it. it sounds like the drivers have been removed or corrupted.
Posted on Nov 13, 2009
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Dell dimesion wont turn on at all
So it doesn't power up at all? I'm only asking because you said it's not the connection.
If it doesn't power up, open the box and reseat everything, something may have come loose during the move.
Sep 21, 2012 | Dell Dimension 2400 PC Desktop
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
PC doesn't recognise hard drive connected via front panel usb?
Use one of the rear USB ports. Mind you, my PC won't deal with it when connected to any IUSB port although it's fine when connected to the router. This is driving me mad...
Nov 02, 2011 | LaCie Space 2 (301515EK) 1000 GB Network...
Euro Pro X 1750 psi Pressure washer won't start. It's plugged in and water is attached. it was fine last time i used it.Now it makes a short noise like it wants to start, but doesn't.
Check the nozzle to see if is plugged. If water can" pass thru , it won't read a water pressure drop and turn on the pump motor.
Aug 26, 2011 | Garden
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
How do I connect my key board to the computer, do I need something to connect it with
Hello there, Mostly, you need nothing to connect it to your pc, just push usb/ps2 in your pc.
Otherwise, some multimedia or gamers keyboards need to install cd with drivers (which came with drivers), so you can use all additional multimedia keys.
Sincerely,
Steve TM
May 28, 2011 | Computers & Internet
Multiple misfires. cylinder 3,6 appear first idles fine. won't rev past 3200 rpms. plugs fine. wires fine. changed 1 coil 3 and 6.
Try shaking the ICM connector see if it effects engine operation if it does inspect for looseness and poor terminal contact,these have a know connection problem especially 1,3,6 connections these are known as (COP) coil on plug
May 08, 2011 | 2002 Hyundai Santa Fe
Acer 3690-2900 trying to use wireless
Cheryl, Most access points are restricted to authorized users; very few are intentionally left open for just anyone to connect to. The few that are open generally don?t require any changes on your PC as long as it is configured to automatically obtain and IP and DNS server. You simply turn on your PC and let it automatically search and connect. Usually when you open your browser the first page you see is a form requiring you to electronically agree you won?t break any laws or do evil stuff. When you are prompted for something (depending on what it?s asking for) you are probably trying to connect to an access point that is restricted. Generally places like motels or other hot spots want you to spend money with them first. Then they give you the password or connection information you need to connect. As far as connecting to an access point that is accidentally left open, to me its like keeping something you found that doesn?t belong to you. Even if you can get away with it, it?s not quite right. For those who aren?t motivated by doing what?s right at least one person in California has been arrested under the same law that prevents illegally tapping into someone else?s cable access. Hope that answers your questions, if not let us know; otherwise please don?t forget to rate this post.
Apr 03, 2007 | Acer Ferrari 4005WLMi Notebook
Intel Pro PC Camera CS430 Webcam Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
