Question about Kodak EASYSHARE Printer Dock Thermal Photo
The printer only prints the lower part of the picture.
    Brigadier General:
  • 3,513 Answers
Hi
Please chek this link..
http://ask-leo.com/why_is_only_the_left_hand_part_of_my_page_printed.html
Thanks for contacting fixya.com
Posted on Nov 13, 2009
Print Job Keeps Cancelling
your computer may not be able to provide that high of a resolution to the printer. It would be like trying to take a color picture with black and white film.
Apr 17, 2014 | Epson WorkForce WF-3540 All-in-One Printer...
Kodak easy share series 3 , only prints lower portion of picture.
Try reinstalling the printer driver. If that doesnt help, try a hard reset: Unplug the printer from AC power and PC, wait about 10 minutes and retry.
You can also do an alignment test. If none of this proves succesful, you either have a bad print head, or problem in the circuitry, which will need servicing.
Jun 24, 2008 | Kodak Office Equipment & Supplies
My HP Colour LaserJet CM1312 has refused to print a one page document which has a few boxes on it with coloured pictures and writing. This has never been a problem on any other printer. It printed out an...
If you edit the photos and save them at a lower resolution, then put the lower resolution photos into the document, that's the quick fix.
A program such as photoshop or corel photopaint are able to do this quite easily. In corel for instance you simply resave the photo as a jpeg, and it'll ask the resolution/quality etc. and you can reduce the resolution usually quite a bit before you lose any quality in the printout.
The other solution is to upgrade the printer's memory.
Inkjet printers usually will not have this issue because they don't need to form the complete page in memory before printing like a laser printer does. An injet's image is formed line by line in the print driver and then streamed to the printer, so the printer's ram doesn't have to take the whole page at once.
Mar 25, 2011 | HP LaserJet CM1312 All-In-One Printer
My computer says that the printer is offline, it worked just fine a week ago.
Did you click on the print manager box, there is a parameter in there that will be checked if it is OFF LINE. Click on that and it will put you back on line. The easiest way to find it is to try and print something, when the little printer shows up in the lower toolbar or if you get a popup when the print failed, you will have access to that info by clicking on the box.
Mar 25, 2011 | HP Office Equipment & Supplies
How do you print a test sheet on a dell 5100 cn of the various colors?
You can see the colors printed on this printer in three different methods. Well, there may be more, but I'll discuss three.
First, there is a menu screen on the printer. you can choose to print a test page from this menu. It should print in all the available colors.
Second, you can open the printers folder on your computer. Find this specific printer and look at its properties (right click, properties). Under the General tab, found in the lower right corner, there is a button to print a test page. This test page is a WINDOWS test page, and will display come of the colors on the Windows logo.
Third, you can open your favorite picture, whether it is one you took with your camera or a sample picture in the operating system. Click File, Print, and be sure the Dell printer is selected.
Good luck.
tony
Jun 10, 2009 | Dell 5110cn Laser Printer
Card Pictures will not print
Change the Printer's Spool Settings.
  • Go to START - SETTINGS - PRINTERS.
  • Right Click on the PRINTER and choose PROPERTIES.
  • Under Printer Properties, select the DETAILS tab and click on the SPOOL SETTINGS button.
  • Change "SPOOL DATA FORMAT" from EMF to RAW (it may already be on this setting.)
  • Click on PRINT DIRECTLY TO PRINTER. Then click on OK.
  • Now Select the GRAPHICS or COLOR tab. If there is an option for RASTER mode, select this mode. Then lower the DPI setting and click on OK.
  • Also, make sure that the Print Mode is set to NORMAL and not Best.
  • Close the Printer Properties window by clicking on OK.
    3. Now set the printer as a default Printer. Right click on the PRINTER icon in the Printers Window and select "SET AS DEFAULT" to place a check mark by this option.
    Please try printing and let me know if that fixes it.
  • Apr 02, 2009 | Creative Home Hallmark Card Studio Deluxe...
    PRINTING ERROR
    It sounds like the printheads are dirty or you have a leaking cartridge. Take the printheads out and clean them with a damp cloth. Just in case you haven't done it yet, do the printhead cleaning procedure. Also try temporarily lowering the print quality and see if the symptom changes.
    Mar 10, 2009 | HP Business InkJet 2800 Printer
    A3 print problem
    i would adjust the margins they are probably set at 0.75 take it down to 0.50 and maybe that will help a bit you can lower it more as well but see if it helps or if a option to fit to page is in your options do that.
    you can also clean the print head.
    Aug 05, 2008 | Epson Stylus Photo 1280 InkJet Printer
    Pictures printing with stripes of color in some programs but not all programs.
    Try new injet cartidges. If your printer has separate head and ink combo, replace the jets. The high quality mode operates the piezo jets at full power and lower setting can cause jets not to open as far. On some preinters, your particalar problem can be the result of too thin paper and the economy setting being used. Use 18lb or 20lb paper and see if it still does it on normal print mode.
    Apr 27, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
    Kodak EASYSHARE Printer Dock Thermal Photo Logo
    250 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
