Question about Zenith ZRY-316 Video Recorder
Ihave a ZRY 316 DVD/VCR RECORDER. Now I can play DVD's, and VCRs and dub okay. But when I record a VCR from a TV program, I can see it is recording, but when I attempt to play back I get a garbled black and white image.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, postback and describe the TV program source; direct cable feed, OTA (over-the-air) or through a receiver / decoder box. Additionally, describe how the Zenith ZRY-316 DVD/VCR Recorder is connected to the TV unit; a single coaxial patchcord or multiple RCA to RCA cables or some other means.
Offhand, a possibility to consider is that the output of the ZRY-316 to its RF OUT (Ch 3 or 4) is interfering with the TV channels received on its ANT IN. This would be more pronounced if the DVD/VCR Recorder is fed TV program from a cable decoder or DTA converter box that uses the same Ch 3 (or 4) at its RF OUT. Consider interconnecting the devices' audio & video using RCA to RCA cables.
Alternately, set the Zenith ZRY-316 to RF OUT to Ch 4 (switch at the back) and set the TV to the same.
A few things to consider:
  • connections are correct, otherwise the DVD & the VCR would not display on the TV;
  • very doubtful if the video head needs cleaning as VCR presumably plays the dubbed from DVD without any garble;
  • since the garble is only on recording TV (RF) signals, then it could be presumed to be an RF interference that causes the "...garbled black and white image...".
Good luck and thank you for asking FixYa.
Posted on Nov 13, 2009
Dvd says cannot record copy protected movie how to fix ?
Depends what you are trying to record? Some TV stations have protection built in so you cannot record. If you are trying to copy a video from VHS to DVD and it's a commercial movie etc then it won't.
You can get a "box" that will get rid of copy protection signals, but only from outside the unit sources. Internal dub to dub protected sources cannot be copied.
Feb 04, 2013 | Samsung DVD-VR357 Tunerless DVD Recorder...
I have recorded on disc many programs from TV with my ZRY-316 recorder, but I sold the unit in favor of buying a new recorder. Unfortunately the discs recorded with the ZRY-316 will not play on my new...
It those dam fanalizing codes of the DVD recorders.Not likely,because it impossible to tell,who is sharing their patent coded contents.Buy those movies decoded solfware,use the computer to re recorded,might work.The codes,not as hard as those Hollywood movies.
Jul 19, 2010 | Zenith ZRY-316 Video Recorder
What are the steps to dubbing off the other tape?
You need a set of RCA AV dubbing cables (available at fine electronics stores everywhere), and a couple VCRs. Plug the cables into the "A/V Out" jacks on the back of the VCR that will be playing, and into the "A/V In" jacks on the VCR that will record.
Also on the recording VCR, use a regular coaxial cable to attach it to a television.
Now, set the TV to 3, fire up the VCR's, and set the recording VCR's TV/VCR toggle to VCR. Also on the one that is recording, set the channel to "INPUT" or "AUX" or something like that. (You're telling it to record what it sees coming from the jacks you plugged the cables into.) Then hit Play on the other machine. You should be able to see your tape playing back. If you do, you have followed these directions correctly, and you're ready to make your dub.
HINT: The first few feet of tape are often prone to dropout and generally sucking. Record a minute of black before making your dub. Mark this on the tape or tell them when you turn it in. They will be impressed.
May 28, 2010 | Sony DTC-ZE700 Dual Cassette Deck
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dubbing VCR to DVD... it records for 20 seconds then stops
Try a -RW disc. Only the higher priced DVD recorders can use the +RW disc.
Electrode
Mar 15, 2008 | Zenith ZRY-316 Video Recorder
Problems with DVD/VCR Player and Tivo
How are you attempting to connect this? Can we get more information, such as your TIVO model and TV model?
Jan 13, 2007 | Zenith ZRY-316 Video Recorder
Zenith ZRY-316 Video Recorder Logo
139 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
