Question about Maytag Neptune MDE5500AY Electric Dryer
My dryer door will not stay closed...maybe the clasp is broken? is there a picture of an unbroken clasp?
  • Maytag Master
  • 7,482 Answers
Check this website...they will have a picture of the door catch and plug with prices for the repair parts
Good Luck,
I hope this helps
http://www.partselect.com/MultiModels.aspx?ModelNum=mde5500ay&searchTerm=&RefineSearch=0
Posted on Nov 14, 2009
Door will not lock light stays on
Usually this is caused by the door being bent, the hinges being bent, or a worn out door strike/catch not holding the door tightly closed. Lol, got kids?? Mommy's little helpers love to lean on the doors(the ones that open/close vertically). Also, slamming the dryer door can break the little plastic arm attached to the door switch--I see MANY switches with the arms broken in-half or the strikes/catches damaged from slamming. Usually a relatively simple repair to replace the strike/catch.
Aug 13, 2015 | Kenmore Dryers
How do I Close the door on my Bosch WTL 500 dryer
Push it closed.. I guess you mean that the door wont stay closed?? If so, the door latch has probably broken. Either the tongue on the door itself or the latch on the cabinet.
Feb 28, 2015 | Bosch Dryers
The Door won,t stay closed on our gas Magic Chef Dryer
Latch is broken and needs replace or may just need reset. Probably been slammed one time too many.
Aug 07, 2014 | Magic Chef CYG4000AWW Gas Dryer
Door on the dryer does not close properly
If door wont stay closed it may need a new latch it could be broken or bent.
The door could also be bent or the machine not leting it close right.
Hope this helps.
Sep 27, 2011 | Whirlpool LER4634J Electric Dryer
The dryer door won't stay closed on my 90-series electric. Doesn't matter if the dryer is running or not. Have to keep the door closed by propping a weight bar against it. Any suggestions to get this...
There is a door catch made of plastic that holds the pin thats sort of arrow shaped on the door... The plastic catch is located on the front of the panel and can be easily replaced....Call the local repair shop/man to get the part....very cheap part maybe a couple of dollars at most... You should be able to remove the broken one with just a set of pliers and a screw driver...doesn't matter anyways its already broken right!! the new one will push and snap right in....Good Luck
Apr 20, 2010 | Kenmore Dryers
The spring in the clasp has broken so the watch band will not stay closed. How can I fix this problem?
replace clasp is the best option..if clasp has 2 buttons on it these can be a easy fix but they always break again so i would replace clasp section or even all the bracelet for the watch .you will need model and serial numbers of the watch then try manufacture or ebay or a repairer
Mar 25, 2010 | Watches
Door will not stay closed
WITHOUT KNOWING WHAT MACHINE THIS IS I CAN ONLY GUESS, & IM GUESSING ITS THE KIND THAT HAS A POST SHAPED LIKE AN ARROW STICK A SCREWDRIVER (FLATHEAD) IN THE BROAD PART OF THE ARROW TO MAKE IT JUST A LITTLE BIT WIDER THIS SHOULD WORK PROVIDED THE CLASP PART IS NOT BROKEN.
Dec 17, 2009 | Washing Machines
Door won't fully latch, light stays on, dryer won't function
There is typically a small plastic piece that catches the door and keeps it latched. The door has the male side and the frame of the dryer has the female side.
Either the male part on the door has broken off (or bent) or the the female part on the frame has broken. Replace this part and you'll be back in business. It is typically called a door latch and it comes with both the male and female parts.
Here is a picture
of a typical one.
Sep 22, 2008 | Dryers
Dryer door won't stay closed
hi,
shut off the breaker- pull the female receptacle clasp out of the front with flat screwdriver and needle nose and squeeze the back of it gently with pliers, replace, if its busted and you get mad, you can buy a standard padlock and latch and install that, that helps in other ways as well, careful to steer clear and watch the inner wall for wires and clearances if your going to retrofit that.
J
Jun 17, 2008 | Whirlpool LER5636P Electric Dryer
Three beeps
Replace the bulb and door switch.. (cheap)
last would be this 3-beep problem..
http://www.youtube.com/watch?v=tq3k22cqjR8
Mar 27, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
182 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
