Question about Goodmans GMP32000 MP3 Player
Need new earphones
Were do iget new earphones for my player as they are smaller than standard ones which is alot of use could you help
I had the same problem as you and solved it by buying and adapter which allows you to use the bigger jack .
have look in maplins they are about £3
Posted on Feb 28, 2009
    Problem Solver:
  • 7 Answers
U will get them in dreams....try today..u will..
Posted on Jan 08, 2008
I have a fuze that is about 3 years old. I have to giggle the plug to hear so Im sure it needs repair. Is it worth it or should I buy a new one. 8 GB/FM
If other earphones dont work then you should buy a new one. If its just those earphones then your earphones are broken and you need new ones.
Dec 31, 2010 | SanDisk Sansa Fuse MP3 Player
Whenever i plug my earphones into my mp3 player I cannot hear my music through the earphones. any idea what the issue could be?
The wire inside the earphones Tore. If these earphones came with the Player then they are probably not very strong earphones. Usually the name brand ones are more durable. I believe it is time for you to buy some new earphones.
Dec 29, 2010 | Philips GOGEAR SA6045 MP3 Player
Only one earphone works and its not the problem of earphones
if the earphones are fine then it is usually a problem with the audio jack. Either the contacts that push on the barrel of the earphone plug have gotten worn out or a connection that is soldered to the board has become bad.
In this case you really have one of 2 options How long have you owned the unit.. if it is still under warranty then have it repaired under warranty by the manufacturer. If it is not under warranty call Apple and ask them how much to get it repaired then base out if it is worth to pay to get it repaired or is it worth buying a new or used product of the same caliber. But id say in my experience its worth it to have them repair it. its actually not that hard to solder on a new headphone connector just takes someone with alot of skills and the tools to be able to desolder the old one and put a new one on.
if you need further assistance i will be here to help. Thanks and have a good day.
Aug 17, 2010 | Apple iPod MA446LL/A MP3 Player
The MP3 player earphones only work sometimes. Left will work the right doesn't, the right works the left doesn't. Somethimes if you move the MP3 player, neither one of the speakers work. We purchased new...
Sounds as though either the earphone's Plug isn't the right size or plug end shape... OR the actual Jack is faulty, and only making intermittent connections... or the wire to them is broken. What is best is take the MP3 unit along when buying any head/earphones and try them in shop.. As for Walmart... Talk to a manager and demand a refund or a change of type... Don't take NO for an answer. Also you don't need to spend that amount for them... any cheap pair that works will be OK. Try before you buy.
Feb 02, 2010 | Audio Players & Recorders
Lcd screen is busted, will it still play music, do I need a certain type of earphones?
get a battery that fits, standard earphones (3,5 mm plug, the small one,)
attach to pc that has usb2.0, copy some mp3's to it, unplug, insert battery, press play and find out!
Jun 17, 2009 | Delstar DS-3512 MP3 Player
Sound to one earphone only unless pressure applied.
try taking a cue tip or something smaller and cleaning out the inside of the earphone port, sometimes dust can cause interference with the headphones
Jan 14, 2009 | SanDisk Sansa e260 MP3 Player
My earphone plugin
Sounds like your stereo jack got damaged. Mine has the same problem. Possible to fix......worth it?
Dec 05, 2008 | Philips GOGEAR SA6045 MP3 Player
Only one part of my earphone works and its not the earphones its the mp3 player
I had this same problem but found a solution on here. Switch it to the off position and get a nail under the button and pull it off. You've now got to fold up a small piece of paper (so it's about 4-8 times the usual thickness) just smaller then the hole where your button was and put it in. Whack the button back on and fingers crossed it'll now play through both headphones... mine did.
Mar 10, 2008 | Apple iPod shuffle MP3 Player
Mp4 ear phones
hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out.
If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board.
But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
Jan 16, 2008 | Konaki MP4-NS MP3 Player
Ear phones only play on one side or the other when pushing the plug in and out.
Your supossed to just keep the plug in, if one doesn't work when the plug is fully in, buy new ones.
Dec 18, 2007 | SanDisk Sansa c240 MP3 Player
Goodmans GMP32000 MP3 Player Logo
44 people viewed this question
Top Goodmans Audio Players & Recorders Experts
Pavel Pranovich
Pavel Pranovich
Tom Chichester
Larry
Are you a Goodmans Audio Player and Recorder Expert? Answer questions, earn points and help others
