Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
Blackberry flip-Has white screen/black clock continually cycling. Have tried hard reset, but it didn't work.
    Scholar:
  • 117 Answers
Hi, I suggest you to reinstall the software and check the handheld.
If you face the same problem even after reinstalling the software, you need to visit the outlet where you have purchased the handheld to service the handheld
I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Posted on Nov 16, 2009
I took out the battery and place it back in, now there's a lil black clock showing off an on then disappears. When i flip the phone open app ERROR 523 and Reset shows up on the screen
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information before hand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
May 23, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
The screen is all white and when i flip it open
just make sure that your phone is original and not a china phone!
Feb 09, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Ok so the screen on my pearl flip just goes blank or the white screen with the little hour glass comes up and itll go like that forever untill i turn it off, plug it in and turn it back on. is this a...
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
Still if it is not working the software of your Handheld might got corrupted, in this you need to reinstal the software or walk into the service center.
Thank you for using Fixya.
Nov 16, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Phone just dies for a few minutes every so often--several times a day for the past ten days. Screen goes black and then there's a little white clock icon on the screen. A few minutes later it's fine...
A) Perform a hard reset on the BlackBerry smartphone.
smartphone.
B) If the display is still not working, verify that the battery is charged by trying it in a different BlackBerry smartphone.
C) If the battery is working, download the latest BlackBerry® Device Software and install it using the application loader tool in BlackBerry® Desktop Manager
Oct 19, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Screen turned black , internet and external LCD i have no idea who is texting or calling please help. I already restored firmware and wiped and did to factory settings and used desktop software removed all...
It sounds like your LCD screen got damaged. It may have been water damage or if dropped the connector for the lcd screen may have come loose
If you g=follow this guide, you can take the LCD apart and check to see if the able is seated probably. If it is seated, then theblackberry LCD screen is damaged and needs to be replaced.
Blackberry Flip 8220 LCD screen Replacement Guide
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Checkout the guide I wrote for replacing the blackberry flip LCD displayscreen. There are also links to by the new pearl flip LCD screens2.gif
Aug 02, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Blackberry flip pearl constantly reboots.
I've had the same problem, particularly after upgrading the OS. I've been able to keep it reboot free for 24 hours after resending the service books from the bberry portal (and I'm even using it unlocked from T-Mobile on AT&T).
Jul 11, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Display on pearl flip when closed is always black
John-
It is possible the backlight or the LCD itself got damaged. The good news you is you can replace it.
Jun 03, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
App error 523
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:1) Remove the battery cover from the back of the BlackBerry smartphone.2) Remove the battery, and then reinsert it after a few seconds.3) Replace the battery cover.
A soft reset is a three key combination that resets the BlackBerry smartphone without removing the battery. It is only available on BlackBerry smartphone models with a QWERTY keyboard. SureType technology and touch screen BlackBerry smartphones, such as the BlackBerry Pearl smartphone, BlackBerry Pearl Flip smartphone, and BlackBerry Storm smartphone cannot be reset in this manner.
To perform a soft reset, complete the following steps:1) Press and hold down the ALT key on the smartphone.2) While holding down the ALT key, press and hold down the right-hand CAP key.3) With both of those buttons still pressed, press the DELETE key. The display on the BlackBerry smartphone will turn off to indicate that the reset has started, and the keys can now be released.
Mar 13, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
The external display on my blackberry pearl flip is empty
i had the same problem. i reset the alarm to go off immediately, then dismissed the alarm. i also reset the default theme. the clock came back to the external display and the daily alarm message went away!
Mar 05, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Reset blackberry 8700
my blackberry 8700g on/off ligt red
Apr 16, 2008 | RIM BlackBerry 8700c Cellular Phone
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
1,133 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
