Question about HP Compaq nc6000 Notebook
I need a replacement hard drive for a compaq nc6000. Will a hd that is already loaded with XP Pro OS and has been used work when I put it in my laptop?
  • 41 Answers
600000000000
Posted on Nov 13, 2009
Hi install Windows 7 on my hp compaq nx6310 Celeron M. and put a 500GB HD I worked fine but after installing some programs are lost anrranque files then I wanted to install windows xp tells me not see the...
restart your computer witht he XP cd in your drive and maiing sure it boots to cd by either pressing F12 or going into your bios and setting the priority to cd first then hard drive second after you have done this if it still cant see the hard drive then the hard drive has developed a fault and will need replacing if you havent formatted it yet try and see if it boots up to windows 7 if it does then it means the xp cant format the drive. if you have more problems then please use the comment below to describe whats being done. Kronoguy
Jun 29, 2011 | HP Compaq Business Notebook nx6310 -...
My old hard drive on my COMPAQ PRESARIO C306US died, after I replaced the drive I tried reloading windows XP and I get an error that the hard drive could not be found. I loaded Ubuntu and it recognized the...
check the HD if its properly inserted,if the old one is working before then the new one you bought my be a damage one. try to replace another HD to see if which HD is working or not.
Jun 06, 2011 | HP Compaq Presario C306US Notebook
I have HP Comaq Presario SR1617CL Desktop PC, part number ED870AA with a Samsung SpinPoint P80 SP1604N - hard drive - 160 GB - ATA-133, I would like to upgrade to a 500GB hard drive. I have a ASUS A8AE-LE...
XP cannot be installed natively on an SATA disk without the appropriate driver which must be loaded during the install - an extremely complicated maneuver. The best way to deal with that is to just add the new SATA hard disk: install XP on the PATA and use the new SATA for your files as a separate partition. The adapter cable can be bought for about $5 from the same shop as the hdd.
All the other modifications are just fine - just remember , the RAM will not be fully recognized and used because of the limitations of the 32bit XP.
Mar 11, 2011 | HP Compaq Presario SR1617CL PC Desktop
Replaced hard drive loaded windows xp pro and still get nonsystem disk error when booting
go into your bios setting and change the boot order to hard drive first..( please rate)
Dec 21, 2010 | HP Compaq nc6000 Notebook
WHAT CAN USE TO REPLACE A MAXTOR 7Y250MO HARD DRIVE? IT IS IN A 6 1/2 YEAR OLD DELL DEMENSION XPS GEN 2 TOWER RUNNING WIN XP. THE OS CAN NO LONGER FIND THE DRIVE AND WILL NOT BOOT UP. I WOULD LIKE TO...
The Dell Dimension XPS GEN2 has support for both, IDE and SATA standards. Your Maxtor is SATA drive, you can use any SATA drive as replacement. You mentioned that the OS no longer find the drive, make sure that you load SATA drivers at your Windows XP reinstallation, maybe your old drive is not defective only not recognized in the installation process. You can download the floppy image with required drivers here, see SATA drivers section. When you start Windows installation, at the Windows Setup Screen you should see, at the bottom of the screen, a message saying "Press F6 if you need to install a third party SCSI or RAID driver." At that point press the F6 button and when the next screen appears press S key to specify an additional device. Select the drivers from the provided list(to load all drivers from the disk, beacuse I don't know which is yours as I don't know the content of the disk, repeat steps to specify additional device), after drivers load your hard drive should be recognized and you can continue installing the Windows XP operating system. Ignore these steps if your hard was already tested and confirmed that is defective. Good luck!
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
Sep 26, 2010 | Dell Computers & Internet
Compaq SR1650NX HARD DRIVE MESSED UP RECOVERY DISK WON'T WORK REPLACED HARD DRIVE CAN'T GET BIOS TO RECONIZE HARD DRIVE SHOWS UP IN BOOT BUT NOT IN MAIN HP SAID TO INSTALL NEW OS HAD OLD 98SE LOADED WORKED...
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Jul 11, 2010 | HP Compaq Presario SR1650NX...
Installation for xp problem
all the hardware on the laptop is most likely configured for windows vista meaning it will not allow xp to load up because your hardware cant run it
Oct 09, 2009 | Compaq Presario Notebook
How to reformat my nc6000 using my os cd?
The NC6000 sometimes has trouble booting to anything other than the primary hard drive once a valid OS has been installed. If you need to reinstall by booting it USB or to a CD/DVD; this works for me as a last resort. (Especially USB which it officially isn't supposed to be able to do.)
Insert the bootable media. Shut the laptop down. Remove the hard drive - but leave it disconnected in the bay. Start the machine, let it detect the bootable device, then hot-plug the hard drive. There is some timing involved, but it works.
I loaded several NC6000 machines running Windows 2000 to Linux and XP this way.
Sep 27, 2009 | HP Compaq nc6000 Notebook
HP Compaq nc6000 powers up and then down automatically
check first the power connector.. and be sure that you power not auto shut off. then instal again the os.. even this vista or xp don'st matter...
as long as you powere is good condition..
Jun 13, 2009 | HP Compaq nc6000 Notebook
Frustrating Keyboard Malfunction (HP Compaq NC6000)
please tell the solution of this problem of keyboard
hp nc6000 mobile technology
Oct 22, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
