Question about NEC Dterm DTP 16D-1 Corded Phone
How do you take out voicemail from the phone so call forwarding can be processed?
    Problem Solver:
  • 14 Answers
I'm not sure that you are phrasing the question correctly. How can I bypass the voice mail box would be a better explanation.
If you take out the voice mail box it will go to the main greeting. Call forwarding to voice mail is call forwarding being processed. Is there somewhere else you would like it to forward to?
If you are just trying to delete your mailbox then you need to know your system manager info. If you do email me at IsaiahJ1980@gmail.com and I can help you further.
Call Forwarding Options:
From Port 1
Find port 01 or Tel 01 by pressing feature 4 from the lowest extension # in your system. Once you have found port 01 dial either of the following:
Call Forward Busy No Answer
Speaker 45, enter the extension you want to forward i.e 103, enter the destination, another extension perhaps 107 and speaker.
Call Forward Busy No Answer to an outside #
Speaker 45, enter the extension you want to forward i.e 103, press 9 and enter the destination phone # and speaker.
To Cancel Call Forward BNA
From port 1: Speaker 46 and the extension #
Call Forward All
Speaker 47, 103, enter the destination extension 107 and speaker.
(You will notice the Feature light flashing after this operation)
Call Forward All to an outside line
Speaker 47, 103, 9, enter the destination phone # and speaker.
To Cancel Call Forward All
From port 1: Speaker 48 and the extension #
Posted on Nov 17, 2009
2 Suggested Answers
PhoneSystems
  • 213 Answers
SOURCE: pressing 620 says forward cleared. voicemail still working
You should be pressing 602 and not 620- 600 clears all forwarding until re-set. See the attatched video for some top up training, more of which you will find on youtube or at www.abbeytelecom.com , I hope that this helps
Posted on Dec 10, 2010
How do I delete the voicemail option on my phone? My phone is a Dterm Series E NEC
Your phone is call forwarded to the voicemail pilot when busy or not answered, so just cancel the call forwarding. NEC uses these phones on several different systems so I don't know what your code is.
Jun 13, 2014 | NEC Dterm DTP-2DT-1 Phone
Forward to Voicemail
If you have 3 way calling ,you should be able to do that, as long as you are talking voicemail and not the answering machine, flash your receiver and dial voice mail, flash and join calls, you should be able to hang up and they will be to your voicemail.
Mar 20, 2014 | Panasonic KX-TG5421 Cordless Phone
How do you put a panasonic KX-T6730 on voicemail instantly if you need to leave the office early?
Press
Dial 50(forwarding program number) on the keypad
Press or
Dial one of the following single digits for the condition you want
0-off
1-DND(Do Not Disturb)
2-All calls forwarded
3-Busy calls forwarded
4-No answer calls forwarded
5-Busy/No answer calls forwarded
Dial the voicemail access code(default is usually 500; this is the number that will ring voicemail)
Press or
Lift handset or press to end
Dec 10, 2010 | Panasonic KX-T7630 Corded Phone
All calls go directly to voice mail
The phone is probably forwarded to voicemail. Leave the handset down and dial "Feature # 4". This will remove the call forwarding option. There are also automated call forwarding options -- Call Forward-No Answer, and Call Forward-Busy. CF/NA will transfer calls to voicemail after 4-rings (for instance). CF/B sends all calls to voicemail if you are on your phone. System programming, by a certified technician, is required to make changes to these options. Hope this helps.
Jul 15, 2010 | NorStar Meridian M7310 Phone
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
How to forward a call to a virtual voicemail box
With the caller on the phone, press a "Voicemail Transfer" button, then the extension number and hangup.
OR
With the caller on, press FEATURE 14, then the extension number and hangup.
May 19, 2010 | AT&T Lucent MLS-12D Phone
HTTC 6800 Not receiving calls in sleep mode
You want to make sure your callforwarding is on. Sometimes when you select sleep mode, the calls will divert directly to Voicemail. Plus, ensure you have signal. Without signal, by default the calls go directily to voicemail. We won't wanna miss a call here. You can follow these steps here. start
settings
phone
services
call forwarding
get settings (wait for a while)
forward all incoming phone calls (check the box)
OK
OK
Exit
In the option to forward calls, there should be an option for the amount of seconds the phone RINGS prior to forwarding directly to voicemail.
IF your HTC device doesn't have the option for voicemail, and your calls are routed else where, contact your carrier for the voicemail number. This is very important!
Cheers!
Jan 30, 2009 | HTC PPC-6800 Smartphone
Avaya ip office manager setting issue
That is for voicemail to email.
Copy, send a wav file as an attachment to email as well as leaving a copy in the phone
Forward, only send voicemail to email address.
Alert, only sends an email to say that you have voicemail, still need to access phone to get vociemail
Dec 17, 2008 | Avaya Lands Phones
Iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Jul 17, 2008 | Apple iPhone Smartphone
NEC Dterm DTP 16D-1 Corded Phone Logo
429 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
