Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Color out of sync ,picture shows double
I was told that I needed a deflation panel board , panasonic discontinued making this particular model, was wondering if by chance you would have or can you get me a panel board serial #TNP 2AH046 SINCERLY "BYGBOI"
    President:
  • 4,402 Answers
I think your convergance amp ic are bad.
The STKs are common and if you have an experienced electronics tech around they can replace them for much less money but the tech must have advanced soldering and IC exchange experience.
The STK ics, two of them, can be purchased on line for around $20 to $40 each.
http://www.partstore.com/GetModel.aspx?MfgName=Toshiba&BrandName=Toshiba&ModelNu...
Partstore has two models available - one for around $40 and another for around $55.
The part number is STK392-110 and if you google you can find them for as little as $6/each but I don't recommend the cheap ones as they are not reliable.
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Don not run the tv till you have it fix you will cause more damage!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 08, 2008
Defective sc board
Try Shop Jimmy. This an online store. They have many TV boards.
Jan 06, 2014 | Panasonic " VIERA 55"" Class / Plasma /...
Intermittent vertical black lines samsung hlp5067w
even technicians who are familiar with those units, before installing new lamps, they use a 'calibration unit' for that or any particular model lamp and calibrate them right after installation. If you don't have the proper calibrator and adjust them right after you installed them, you will get that result. Even experience techs come across that problem if the calibration is not done properly. Also, each lamp for a different color value, has its own calibration/sync values.
Nov 18, 2013 | Televison & Video
Toshiba 50HP66 Plasma TV Problem - TV comes on but no picture. OSD shows up as vertical stripes on black background. picture sometimes black, sometimes multi-colored verticle stripes. Should I change the...
Generally this problem is in your signal board. You may also know it as the scaler board, as you mentioned. I have not repaired this particular model. But I would first suspect the the signal board (scaler). If you are not sure what this is, it is the board with all the RCA Jacks and RF connections. The problem in this area are bad or failing capacitors. Thanks for asking and show all hands of support!
May 02, 2011 | Toshiba 50HP66 50 in. Plasma Television
Color section in tv receiver
can I know what is the answer for that question.
Feb 23, 2010 | SAMTRON 96B 19" CRT .22MM 1600X1200...
My panasonic dlp model pt43lc14 shows yellow picture
there are many mirrors, filters and lenses in the projection assembly, This happened to me too. I took the assembly apart and there was one of the filters that had gotten charred. I peeled off the plastic filter and cleaned the glass it was attached to then put the TV back together, now have a perfect picture again.
Dec 19, 2009 | Panasonic PT-43LC14 43" Rear Projection...
My rear projection TV has color spots in the picture, most noticeable on light color picture
What is the make and model of TV. If it is a Panasonic that has different colored spots such as pink, blue etc. Then you need t6o contact Panasonic as this is a memory reset that they have to perform on the LCD driver board. Other brands of LCD projection sets that have spots that appear all over the screen mostly on white back rounds are almost always dust that has settled on the LCD panels. This requires a technician to clean the LCD panels if possible.
Dec 17, 2009 | Hitachi Televison & Video
My Toshuiba 46RV530U tv has developed an image
Sounds like you need to try reseating the lvds cables on the t-con board.This board is located at the top of the set in the center.You will have to remove the metal shield covering the board.Then you will see to flat cables connected to the board,one for each side of the screen.carefully unlock the connectors and remove and replace the cables.If this does not work you will need a new t-con board.I'm not sure about this particular model but sometimes the t-con board is only available as part of the lcd panel assembly.Good luck!
Oct 15, 2009 | Toshiba REGZA 46RV530U LCD TV
I have a Thermador Model C302ZS
I did too!! My appliance guy told be to but it on the curb - it wasnt worth fixing and we only had it 3 years!!!
Aug 17, 2009 | Thermador C302U Electric Double Oven
Panasonic PT 51HX41E flickering colors
ok her is a good test for u, bring up the pip on screen and see if the picture is the same as the main picture ok.now if at is it sounds like to me that u have a bad pip board that is causeing your problem u can bypass the pip u just need to jump the video in to the video out and sync out and in and remove the pip most of time i have found that the small caps go back on the board and u lose snyc and that is y your picture goes black and white with blinking color in the background. now the stk392-150 is a better chip then what u had in it but convergence problem has nothing to do with color snyc. i hope this will hp u marty
Sep 18, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
