Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence issue... I tried to manually fix it through the menu option without any luck. The convergence does curve at the top and bottom of the screen.
    Problem Solver:
  • 12 Answers
It seems the solder is broken in Vertical Convergence Amplifiers or it is damage internally. This model has 2 Conv. Amps: 1 for Horizontal (Red, Green and Blue) and 1 for Vertical Convergence output (Red, Green and Blue), if the convergence does curve at the top and bottom, it is because Vertical Converegence output is no good. The Conv. Amp. costs around 20 dlls. Thats why you can not fix it with the Menu option. Good luck!
Posted on Mar 27, 2010
I have 52" rca/ge itc
replace the 2 convergence STK IC BEFORE replacing the IC make sure that all the pico resistor are not open check the resistance with an multimeter replace any open reading resistor.replace also all bulging capacitors on the convergence section...good luck let me hear how it goes.
Mar 18, 2011 | Televison & Video
HD52W66: Convergence problem. I know this because the picture is wider at the left and right sides than it is in the middle and the RGB are separated. I have read my manual and several posts in this...
You have a Blowed Fuse on the Deflection board FL231
it will be on the righthand side of the FBT flyback Transfomer there is 3 of them in a Roll they will look like small brown retrangler caps ,But they are fuses.06amp it will be the one in the Middle.
Partstore.com has them 1-866-925-7278
You can take a pair of plyers and pull Top off of them,they just snap back on top.
Deflection is the bottom lefthand side board.
Nov 01, 2010 | Televison & Video
My t.v. is blurry and is showing everything in double it almost appears to have a curve at the top and bottom
Its most likely a easy fix. does the auto convergence option still appear under the on screen menu's setup screen or has it disappeared? Let me know and I will asist with what you need to most likely correct the issue
Mar 28, 2010 | RCA R52WH73 Projection Television
I have a Hitachi 43 " projection tv. There was double image in green and purple. I was able to fix it manually. The auto focus would not work. Now the problem is the appearance is curved at the top and...
Pull front bottom panel off of TV on convergence board where ICs are in Front of board is a setup switch Small blue contact switch Press and hold untill convergnce Pattern appears Now aline convergence, you must have you hand unit that came with TV.
Oct 02, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43FDX01B green is out of whack
The green is not adjustable in the customer menu because it is considered the 'master' color. It is adjustable in the technician mode however but if it is curved it won't even adjust properly that way either. The problem is the convergence ampifier responsible for green convergence has failed. The convergence output IC's need to be replaced.
May 27, 2009 | Hitachi 43FDX01B TV
Picture not clear
CONVERGENCE problem.. with convergence problems on these sets i always start the diagnoses with some questions. IS the picture curved in at top and bottom? or is it just in certain parts of screen. Go to setup in cutomer menu do you have the convergence option in the menu. if you do not try reading the fl231 fuse problem in the tips and tricks section of this website. that is a simple and inexpensive repair. if you do have the convergence option then you may have a problem with one of three different cuirit boards
Apr 03, 2009 | RCA R52WH73 Projection Television
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
Rca projection tv
this is a indication of convergence problem. the curved picture indicates total or a complete loss of convergence power. I first recomend you read the artilce in tips in tricks section. the fl231 problem it might be this if you do not have the convergence options in setup of customer menu. if not it might be a convergence power board issue
Oct 12, 2008 | RCA HD52W59 HDTV Projection Television
Convergence. shadowing, arch top and bottom, red and green colors
You have a convergence problem. i see these set all the time at shop. first consult the article in tips and tricks section the fl231 fuse problem. it might provide some answer and might turn out to be a simple repair. If you do not have the convergence option under setup in customer menu then i say you have that problem.. otherwise it sounds like a convergence power board issue. if you have the options try autocovergence first and then if that fails try manual convergence of red and blue if the dont move then it will be convergence power board. let me know and ill try to talk you through it
Oct 06, 2008 | RCA HD52W59 HDTV Projection Television
Picture has 3 images, all different colors (red-blue-green) screen looks concave in the middle top & bottom
This is what is known as convergence..(very common)... first question DO you have the "CONVERGENcE" option in your setup menu?.... if you dont there may be a special fuse issue... if not then more than likely it is what is known as convergence power supply issue. you have complete loss of convergence?
Jun 01, 2008 | RCA D52W19 52" Rear Projection Television
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
213 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
