Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
Rocketfish enclosure is blinking and PC won't recognize it
Download for a driver for rocketfish rf30HUB4
Test it on other computers and if they recognize it try to download driver updates to your computer which help to recognize external devices.
Jun 03, 2013 | Rocketfish Superspeed 4 Port Usb 3.0 Hub...
I have a aver tech 3.5" HDD enclosure i need the drivers for window 7
There are no special drivers - the unit (when it has a disk in it - it won't be recognized without it) will be recognized as a generic Removable Media and will use the generic driver.
Sep 09, 2011 | Averatec Computers & Internet
I have the rocketfish hard drive enclosure and when i started to use it on the my MacPro it was working fine then it just stopped working and stopped being recognized.
The internal connection of the hard drive has probably become dislodged. Open it up and reconnect it firmly. If that does not resolve the issue the drive may simple have died (the hard drive, not the enclosure)
Apr 22, 2011 | Rocketfish 25" EIDE ATA HARD DRIVE...
Can I boot off the drive from/in the Rocketfish drive; with the operation system that's installed on such as Win XP?
Yes but can be difficult. First you need to make sure your motherboard can boot brom a USB connection. If so then you have to format and install an operating system. Linux would be your best bet to try it out as that particualr operating system is free and has been developed with unusual installations in mind. I would suggest ubuntu
Apr 20, 2011 | Rocketfish RFAHD25 Sata 25 Hard Drive...
ESATA hard drive enclosre difficulties
If you are sure the connections between the external case and the hd inside are good then the hd itself is dead, nothing you can do but junk it.
Jan 12, 2010 | Computers & Internet
The 250g wd hard drive icon disappeared from the mac desktop and list of devices, without being disconnected. It is still vibrating, 1 of the 4 lights remains on,I had the geek squad at Best Buy plug it in...
If they plugged it into a WinPC, the PC won't be able to read the drive.
More then likely the SATA-to-USB card in the drive has gone bad (like mine did.)
I ended up buying a rocketfish 2.5" SATA HD enclosure kit from BestBuy... now my drive works fine.
Good Luck!
Oct 18, 2009 | Western Digital WD Passport 250GB Portable...
500 GB Fantom Drive not recognized on either of my Macs. Tried Firewire and usb; blinking light turns to steady red.Worked fine for about 2-3 years.
The symptoms don't look too good. Looks like the host controller is querying the hard disk (blink) and not liking the answer - or lack thereof (red).
It looks like the internal disk is defective. Sometimes the disk can be (possibly partially) recovered by disassembling the enclosure and mounting it in another enclosure or directly inside a compatible desktop PC.
Aug 14, 2009 | Fantom Drives 120 GB Hard Drive
Blinking lights and not recognized by computer
Try to remove the internal drive from enclosure and connect directly to PC. Does it show up this way?
Does it make any new clicking/knocking/whirring/grinding sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
Nov 04, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
367 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
David Payne
David Payne
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
