Question about Spark Plugs BR4HS Plug 10/BX #3322
I have a 2001 ford mondeo ,unfortunatley it is misfiring on one cylinder.i was wondering how difficult it is to change the spark plugs and would welcome some much needed guidence thanks.
    Sergeant:
  • 399 Answers
First get the correct replacement spark plug make sure y check the gap on the plug before fitting y will neen a socket to withdraw and refit your plug if changing more than 1 do each 1 seperate so y dont mix up the ht leads
Posted on Nov 13, 2009
  • Muhammad Munir Khan
    Muhammad Munir Khan Aug 19, 2014
    Check the ht leads, it also some time develops insulation defects
F150 misfiring
could be injectors swap injectors see if the code changes to the cylinders you swapped it with..and what do you mean water in cylinder like inside it?
Mar 04, 2014 | Ford Expedition Cars & Trucks
2001 mercury grand marquis reading code p305 misfire, spark plugs and coils changed
If you changed the #5 Coil then the code was wrong
You get lots of wrong codes on a ford, as a bad coil
spikes the pcm when grounding out to fire the coils
secondary side
Try putting the old coil back & walking the new one to
another cylinder,may take many days & many miles of
driving to get it fix,but better than a shop guessing, because
they hate fords
Jan 24, 2013 | 2001 Mercury Grand Marquis
2001 ford taurus 3.0 v6 code p0306 misfire
code p 0306 is misfire detected no 6 cylinder causes electrics
more likely a bad injector , injector wiring or dirty tip
May 05, 2017 | 1997 Ford Taurus
# 4 and 5 misfire
either you didn't get your coil packs pushed on all the way or they are faulty
Dec 31, 2011 | 2001 Ford Expedition
I have a 2001 Focus that is showing a #3 misfire, changed the spark plugs and wires and it is still running rough? What next?
had the same thing with my crown vic on the #8 cylinder. changed plugs and wires. still missing. wound up replacing the coil pack. you can check resistence of the coil between companion spark plug towers. ford marks each tower with 2 cylinder #'s. resisistence should be around 10-12 ohms
Mar 15, 2010 | 2001 Ford Focus
Hi there i have a 1.8 16v duratec ford mondeo 2001 its developed a misfire under load if you accelarate hard it clears
check your spark plug leads,and plugs,hasnt got wet recently,as after steam cleaning this can happen or plug leads getting tired
Oct 25, 2009 | 2001 Ford Escort ZX2
Ford mondeo 2001 has misfire and wont tick over
Do a tune-up or clean your spark plugs.
Sep 07, 2009 | 2001 Ford Focus
2001 ford taurus error code p0303
That is a cylinder misfire code have you had the plugs changed, could be a bad plug maybe bad coil, or injector how does it run
Jul 01, 2009 | 1999 Ford Taurus
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
186 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
ken skalski
Thomas Perkins
Thomas Perkins
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
