Question about Philips Magnavox MWR10D6 DVD Recorder
Recording t.v. ok here is my problem i have my magnavox mwr10d6 dvd player hooked up i tried to record a show form direct t.v. because i had to work, i tried it befre i left to make sure it worked but after 5-10 minutes it brought up some error message and i have know idea what to do now. plz. help me with this problem thanks in advance.
It is probably an error message that says, "This program is not allowed to be recorded." This is a common problem with this model and I am still searching for a way to fix it. Mine does the same thing.
Posted on Jan 11, 2008
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
It will not. The US models will only play Region 1 or Region ALL DVD's, and the UK is a different region entirely. There are illegal hacks to make it work, but since it is illegal, I will not post the directions here. Suffice it to say that there are videos on YouTube that show you the illegal method. Good luck!
-Tha Mp3 Doctor
Feb 02, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Play the video on your through your recorder if possible, then record it that way. It works for me. Just go to your watch tv setting and record it off channel three while the vcr plays the video.
Jan 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I need a manual for Magnavox dvd/ recorder for MWR10D6
Although this is a Magnavox DVR, it is made by Funai. The manual for it can be found at:
Hope this helps!
Jan 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Is a Magnavox MWR10D6 DVD Recorder codec or driver needed to play DVD disks on computer?
There are work arounds... but the reason is when its burnt and finialized its written in .vob format which is dvd mpeg2 format. majority of windows media player codecs wont pick it up. divx does. its just the format its burnt in and you cant change obviously. you can just try like nero showtime which always works or ending up ripping the disc on the computier but that might defeat your purpost of burning them in the first place. Its not the dvd recorder i may add, its just the format. by the way its a magnavox unit made by funai... and trust me your not going to get much out of their. your better off going into forums finding more high depth problems if you really want this to work for firends and families and such.
Oct 22, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Cannot record in +VR mode
check to see if the U-verse box is in HD mode. If it is, change it to standard definition and the problem should be solved.
Menu -> Options -> System Settings -> Aspect Ratio
Sep 28, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Dvd recorder mwr10d6
The manual is located at: (copy and paste in your address bar) hope this helps!
Jun 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Brain fade
The manual is located at: (copy and paste in your address bar) it shows some helpful connection scenarios...hope this helps!
Jun 02, 2008 | Philips Magnavox MWR10D6 DVD Recorder
You need to finalise the disc before it will play in a DVD player (DVD+-R), or make edits compatible (DVD+-RW)
Check out the "Playing the discs in other DVD players" section in the "Recording" chapter of the manual. (Page 36)
If you don't have the manual, it can be downloaded from this link
Mar 21, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Magnavox MWR10D6 can't record from camcorder wrong channel
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Jan 06, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
206 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
