Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Hidden number the contact names are visible but the numbers aren't
How can I find the model number?
The model identification plate may be hidden on the rear panel or inside around the area of the broiler. Identification data also could be hidden behind the control panel.
Mar 11, 2016 | Ovens
Need location of serial number oniver johnson revolver
Hello! Many Iver Johnson and U.S. Revolver Co. revolvers have a visible serial number on the trigger guard, under top strap, or bottom of ****... However except for earliest guns, the real serial number is hidden on the grip strap under left grip panel with a letter prefix to identify the years made....Guru...saailer
Mar 10, 2012 | Boating
Hi. The contact on my phone memory are not visible. Please help
hi, try check the CONTACT on your phone Menu, Click on it.....scroll down till you get to settings, then CLICK on CONTACT VIEW and SELECT......NAME AND NUMBER.
cheers.
Jul 13, 2011 | Nokia 5800 XpressMusic Smartphone
How do i set the blue tooth settings on my nokia c3
From your phone's menu, select 'settings'.
Go to 'connectivity', select 'bluetooth'. Under the bluetooth menu, you would see the following sub menu
1. Blue tooth
can be set to either 'on' or 'off'.
2.conn. to audio access - you select this if yuo want to connect your phone to a bluetooth earpiece.
3. Paired device
under this, you would see 'add
new device'. You select it if there
is a new device you want to add.
4. Active devices - it shows any device that is active.
5. Phone visibility.
Select 'always visible' if you want
your device to always be visible
to any active device.
Select 'temporarily visible' if you
want to be temporarily visible.
Select 'hidden' if you want to be
hidden. To other devices.
6. My phones' name. Select this to change your phones' name from the default to any name of your choice.
Hope this was helpful? Please do indicate. Success.
Apr 11, 2011 | Nokia C3 Cell Phone
Trying to connect Nokia 5800 to prowave bluetooth car kit
you have to make your phone visible to other devices. to do this, go under settings, make sure bluetooth is on, then adjust the visibility of the phone Settings
Select Menu > Settings and Connectivity > Bluetooth.
When you open the application for the first time, you are asked to define a name for
your device. You can change the name later.
Select from the following:
? Bluetooth — Turn Bluetooth connectivity on or off.
? My phone's visibility — To allow your device to be found by other devices with
Bluetooth wireless technology, select Shown to all. To set a time period after which
the visibility is set from shown to hidden, select Set visibility period. To hide your
device from other devices, select Hidden.
? My phone's name — Edit the name shown to other devices with Bluetooth wireless
technology.
? Remote SIM mode — Enable or disable another device, such as a compatible car kit
accessory, to use the SIM card in your device to connect to the network
Mar 23, 2010 | Nokia 5800 XpressMusic Smartphone
I don't now how i have to found my chassis serial number ...mighty max 89
In most cases, the chassis serial number is hidden underneath the seats or carpet. The best bet to find it, even if it takes a few hours to do, will be to remove all the seats and carpets from the vehicule. That way you will have the whole floor visible and you will have a much better chance to find it. You might also find a cap along the way labeled Chassis Serial Number which will hide the number stamped on the sheet metal, and you won't need to go any further. On my toyota echo 2005 it's hidden underneath such a cap underneath my passeger seat between the 2 mounting bolts for the seat for example.
Jul 08, 2009 | 1989 Mitsubishi Mighty Max
Nokia E66 Incoming name or number of callers not
It's because the caller using voip (ie Skype or similar with hidden id)
Jun 04, 2009 | Nokia E66 Smartphone
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
