Question about Photography
T50 35 mm Canon how to open film compartment - Photography
  • 10,319 Answers
Pull up on the rewind handle
Posted on Jan 01, 2010
Loading film in canon tlb
Follow the illustrated instructions beginning on page 27 of the manual.
Sep 27, 2012 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Canon prima super 115 film type camera which type batery use
It takes one 3V lithium battery, CR123A or DL123A or equivalent.
If you need a manual, you may download a copy at http://www.cameramanuals.org/canon_pdf/canon_sureshot_prima_105_zoom-1.pdf
Apr 20, 2012 | Canon Prima Super 105X - Point & Shoot /...
How do I rewind the film in a canon sure shot supreme?
I have a cannon sure shot and it is digital and has no film. Open the battery compartment and pull out the sim card.
Feb 17, 2012 | Canon Photography
I HAVE A CANON EOS REBEL T2 35MM FILM CAMERA AND AM PURCHASING A CANON TI1. CAN I USE THE SAME LENS ON BOTH CAMERAS?
Yes, you should be able to use them. Be aware, moving to digital there is a 1.6 crop factor. The means your 100 mm lens will have the field of view (FOV) of a 160 mm. No, it does not mean it is a 160 mm it is the fFOV is the same as a 160 mm. Also, at the other end is were you will most want to purchase a wide angle lens.
Example: your 28 mm film lens now has the FOV of 44.8, not wide angle. As you can see wide angle is where the move to digital crop sensor cameras lose out. To get back to wide angel you would need a 17 mm lens, that would give you 27.2 mm FOV.
To figure FOV take the lens multiply it by the crop factor. On a Canon it is 1.6, on a Nikon it is 1.5, the 4/3 sensor is 2.0.
Nov 01, 2010 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
I cannot find where the memory card or film goes in this camera.
Your camera takes APS film. It's an obsolete system these days but the film and processing are still fairly easy to get.
The film loads into a compartment on the bottom of the camera; you open the compartment by turning the latch on the right hand end of the camera (as viewed from behind). The battery fits into a small compartment on the lower left back of the camera.
Click here to download a manual for your camera.
Enjoy your camera, and please take a moment to rate my answer.
May 11, 2010 | Canon Elph LT 260 APS Point and Shoot...
How to open filnm compartment of old 35mm nikon
Is it an SLR model?
I am not familiar with Nikons; however, Minolta and Canon SLR film camera's film compartments are opened by lifting up on the film rewind mechanism on the top left side of the camera.
If the Nikons are designed like Minolta and Canon, there will be a small tab to push in at the bottom of the camera. This releases the film and allows it to be rewound. At the top left will be a small rewind lever that is used to do the rewind. The part of the camera that the rewind lever is attached to is pulled up to open the back of the camera.
Oct 14, 2009 | Photography
WHICH LENS WILL GIVE THE SAME RESULT OF 50 MM LENS IN FILM MODEL
To figure the equivalent coverage comparable to a film camera, multiply the number of mm by 1.5. Example: a 50mm lens will be like a 75mm lens on a digital camera.
Sep 08, 2009 | Nikon DSLR D90 Digital Camera
I loaded the film but display window shows a flashing zero
Go ahead and try anyway. A ruined film is far cheaper than a useless camera or a professional repair. In any case, if the film hasn't loaded properly it will only be the first short length of film which is ruined. As this is a newly loaded film you haven't any risk of losing any undeveloped photos.
Auto spooling film systems are great when they work, but sometimes are a real pain and some cameras seem really picky about having a film leader of precisely the right length. See if you can engage the the film onto the spool manually.
May 14, 2009 | Canon Prima Super 105X - Point & Shoot /...
Photography Logo
147 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
