Question about Panasonic KX-FP121 Plain Paper Thermal Fax
Document sent is blank for recipient
I have a Panasonic KX-FP121 plain paper fax. For 2 days now, when I send a fax it is only blank white paper received on the other end. Also the machine on my end seems "louder" than in the past while the paper is being fed through the rollers.
Help.
  • PMaiCon Jan 08, 2008
    Machine does not copy either. haha text IS face down. Is it possible to replace the "scanner light"?
    This unit is about 6 or 7 years old. I guess it doesn't owe me anything.
  • 417 Answers
Hi there check the machine scanner light by putting the original in the feeder and doing a copy. If the printout comes out OK then it either could be the other fax machine you are trying to send it to or you have a intermittent fault with your scanning lamp (Section).
You also must make sure that the original is text face down.
Hope this helps you
Thanks J
Posted on Jan 08, 2008
  • Jason Collin
    Jason Collin Jan 08, 2008
    The best this it see if you can get a second hand one that has a problem with paper feed and then change the scanner unit. There is a slim chance that you might be able to get the scanner ass'y' but don't hold your breath as after all it is 6-7 years old.
    Sorry I couldn't be any more help
    thanks J
Fax won't send
try sending a fax using your fax on another telephone line because your phone line might be faulty.also try sending to different fax numbers to see if it` is your fax which has a problem or the other
Aug 21, 2009 | Panasonic KX-FP121 Plain Paper Thermal Fax
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
''Document Jammed'' error message
Open the document feeder and look for a switch actuator stuck in the down position.
Nov 19, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Sending Faxes
there is no need to change the setting.just feed the document to be sent and dial the number of the recipient.after hearing the fax tone press enter key
May 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Need the driver for it
You can't use it as a printer, it has no connections for the PC.
It's just a Phone/Fax/Copier.
Mar 04, 2008 | Panasonic KX-FP121 Plain Paper Thermal Fax
Journal print out
It should be in the manual how to change this but within the menu button you will need to sort through and enter the one that says TTI settings within there, there should be a auto journal section you should set that to error only so when a document doesn't go a error sheet is printed.
Please let me know if you cannot find the manual as I will try and find one from work.
Hope this is useful for you
Thanks J
Nov 17, 2007 | Panasonic KX-FP121 Plain Paper Thermal Fax
Panasonic KX-FP121 Plain Paper Thermal Fax Logo
180 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
