Question about ASUS K8V-MX Motherboard
At first I had a Smart Drive Failure so I changed my Harddrive and now it say no hard drive detected could it be the Ide cable
  • Tim Swiercinsky May 11, 2010
    Is Auto detect set in your bios for HDD?
  • 3,600 Answers
Yes it could they do fial normally at the connectors try replacing with the right ide cable. then if it does not work make sure the jumper on the drive is set to master.
Posted on Nov 13, 2009
What happen if i dont put jumper in a hard a hard drive?
If you don't put jumper in harddrive is detects it as cable select means if you connect your harddrive to middle socket of ide cable and then it detects it as slave but if you connect it at the end of ide cable it detects as slave.But make sure that otehr device is not set as master only 1 device is set as master or slave .
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
SMART failure predicted on Hard disk 2: toshiba mk1637gsx
back it up immediately, the software on the HD has detected something failing, and it is telling you it is time to back up that drive, and replace the drive, these reports, are usually 100% right.
Feb 17, 2010 | Toshiba MK1637GSX 160 GB IDE Hard Drive
How do i manually detect a hard drive in my bios
When you enter setup/BIOS look for "IDE devices"--change the options to detect your harddrive
Dec 18, 2009 | Seagate Barracuda 7200.7 200 GB Hard Drive
Hard drive goes on blue light go around once pc
Tried to boot the computer in bios. Check if the harddrive is detected in bios. If not detected. Shut down the system,take out the power cable.open the tower and disconnected the hdd IDE cable and connect it to a differnet IDE port. Restart the system and boot in bios check if hdd detected. If still not detected possible issue with hdd. Try connecting on different computer if still issue persist replace Harddrive.
Aug 18, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Will not detected any ide hard drives
hELLO THERE:
YOU NEED TO VERIFY THAT THE RIBBON CABLE IS PROPERLY INSERTED INTO THE MOTHERBOARD AND TO THE HARDDRIVE THERE SHOULD BE A RED STRIP ON THE RIBBON THIS GOES TO THE #1 PIN ON THE BOARD AND THE DRIVE. ALSO IF YOUR DVD DRIVE IS OPERATING SIMPLY UNPLUG THE CABLE FROM THE DRIVE AND TRY IT ON THE HARDDRIVE AND REBOOT TO BIOS AND GO TO THE HARDDRIVE SECTION TO SEE IF YOU HAVE ANY HARDDRIVE SHOWING UP NOW. THIS WILL POSITIVLY TELL YOU IF THE OTHER CABLE MIGHT NOT BE ATTACHED PROPERLY, OK? IF SO JUST MAKE THE NECESSARY CHANGES AND THAN REBOOT.
BEST REGARDS MIKE
Aug 02, 2009 | ASUS P4S800D-X Motherboard
Hard drive failure compaq presario 2200
If the bios is showing no ide, means that your ide hard drive is not being detected.
This can be caused by some motherboard failure, some bad cable connection or caddie connection or bad hard drive.
Nov 05, 2008 | HP Compaq Presario 2200 Notebook
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Hard Drive detects immenent failure.
If this is a brand new hard drive from a store return it for a new one. Hard drives have a built in feature called SMART. For some reason the SMART function is reading that there is something very wrong with the drive. If you have more than one hard drive installed on the system make sure SMART is detecting it on the new drive and not the older ones by unplugging the other drives from the motherboard.
Aug 11, 2007 | Compaq Presario 5005 (470014-507) PC...
ASUS K8V-MX Motherboard Logo
61 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
