Question about LG Studioworks 440SI 14" CRT Monitor
When i start up my computer it says on the monitor out of frequency
  • 115 Answers
when You start the monitor please press F8 button of keyboard upto dos screen come and select a option that Enable VGA Mode and press Enter.Might be problem will resolve.login through administrator and set the display setting as 1024*768 .If again problem comes that out of frequency ,then restart the system and press F8 and Enable VGA Mode and login and re-install the Graphics driver again.If issue not resolved then problem with VGA port in CPU or VGA Cable not supporting gt it replaced.
Posted on Nov 14, 2009
I get a message, "Frequency out of range. Nothibng else. The menue and other buttons don't do anything. Nothing else shows. I swapped out the monitor and the new one works.
This problem arise when your computer AGP driver not adjust monitor frequency.you fix it restart your computer and run safe mode settings resolution area(must be choice less area)or select 1024X768 pixel monitor frequency 60Hz press apply set OK.restart your computer.Run again normal mode.May be fix your problem.
Dec 27, 2009 | Princeton Digital VL1916 19" LCD Monitor
I have waves on my screen, what do I need to do to get rid of them?
you don't say whether your monitor is crt/tft....
either type the problem is likely to be refresh rate of the monitor...
try this... (xp pro sp2)
  1. Open Display in Control Panel.
  2. On the Settings tab, click Advanced.
  3. On the Monitor tab, in the Refresh Frequency list, click a new refresh rate
  • To open Display, click Start, click Control Panel, click Appearance and Themes, and then click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
good luck, rate if useful please
Oct 27, 2009 | Computers & Internet
WHAT TYPE OF MONITORS WILL REPLACE THE HP A4331D UNIT?
http://www.monitorworld.com/Monitors/hp/a4331d.html
http://www11.itrc.hp.com/service/home/home.do?admit=109447626+1251146190411+28353475
You need to know what frequency the computer is outputing. That monitor will take a wide variety of inputs. And, your application can change the output as well. You can check the two links I provided, and HP will have some recomendations, possibly pricey, but they'll work.
Some multisync monitors will display the input frequency is when it comes on. Try connecting the monitor when the application is running, and when it's just on but idle. If it has a menu screen (monitor), open that and some have the current frequency being used listed. With those two ranges, you should have a starting point.
Aug 24, 2009 | HP A4331D 20" CRT Monitor
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
You need to install the video drivers for your monitor. Go into SAFE mode to install them.
Mar 29, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Out of frequency range set low resolution or refer monitor manual
TO RESET IT START YOUR COMPUTER IN SAFE MODE AND GO TO DISPLY SEETTINGS SET YOUR MONITOR AT VERY LOW 32BIT 800 BY 600 PIXELS IT WILL SOLVE THE PROBLEM THAN RESTART THE COMPUTER
Feb 06, 2009 | Compaq CV 7500 17" CRT Monitor
Out of frequency LG500g
15"LG Studioworks500g Monitor Supports Up to 1024by768pixel resiolution.
First U can check UR system res is High and than Go to Enable VGA mode on ur system.
Sep 20, 2008 | Computers & Internet
X2gen 19 inch monitor
It sounds like a heat problem in the monitor. It could also be a computer graphics problem. Leave either the computer or the monitor on for a while and then turn on the other device. try to discover which is needing to be warmed up. The buzzing and problems with the other RF devices around mean that the monitor or computer is emitting frequencies so it will affect the TV and maybe the computer. I found my computer emits these frequencies. I can't listen to AM radio when the computer is on.
Sep 03, 2008 | X2Gen MG19MY 19" LCD Monitor
A_turkovsky@yahoo.com
ya u enable vga mode hit f8 at start up in xp select vga mode ok resets u then use 60 hertz man and its native res ok only update drivers ect mark me ask fit ya ok thx nick
Feb 08, 2008 | ViewSonic VX1935wm LCD Monitor
Monitor installtion
Hi Robin,
Hope this instruction well do solve like I met some problem like this. Try to reset the monitors setting manually in OSD (on screen display) mode. Look for frequency settings start at lower and have test it all. Respectively try to configure the video card frequency settings at Operating System GUID (Graphics user interface display) video card setting properties. Start from lower frequency and notice the each changes. When perfectly proportionate select Apply settings.
Best regards,
Rosener Guyano
Nov 13, 2007 | ASUS VW192S Monitor
LG Studioworks 440SI 14" CRT Monitor Logo
91 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
