Question about Cell Phones
I have a lg vu; and it will not charge!! i've
I have a lg vu; and it will not charge!! i've replaced the battery and charger and still same thing!! when it does charge after 3-days of none use and it'll go 2-days then i'll plug it up n i have turn-off ''music-sync'' whatever that is before it'll charge and sometimes it won't charge...!!!! how much this phone cost u'd figure it would last longer than a year at least...!!!
  • Anonymous Mar 13, 2014
    my dell hasn't been charging and it has been plugged in for more them 2 days.
Lg vu will not charge...even though it says it is charging
your going to need a new battery and im guessing you use it while its charging ..dont use it if its on the charger
Nov 05, 2009 | LG Vu CU920 Cellular Phone
My lg cu920 phone reads a full charge for a second and then shuts down.
charge ur battery with external charger wich can charge ur battery with out phone if it works thats mean ur phone is not charging ur battery clean the battery terminal at phone and at the battery also or if it dose the same thing then change ur battery cuz its not holing charge ...
Oct 10, 2009 | LG Vu CU920 Cellular Phone
How long the battery have to charge for firs time
doesn't take the LG long to charge. This could be due to the charger not working properly or the battery is no longer able to take a charge.
Aug 05, 2009 | LG Vu CU920 Cellular Phone
My lg vu will not charge
There are 2 possible problems you are having. You charger is going bad as evidenced by th cable going bad. Take it to a carriers store and try a different charger.
The other issue may be the charging port is going bad. Having to tape the charger may be an indication of that.
Try a different charger first but if that is not the problem check out the following link for ways to fix the charge port on your LG VU
LG VU Charge Port Repair
Jul 13, 2009 | LG Vu CU920 Cellular Phone
LG Vu Wont chrge correctly
Your charging port is probably going bad. It seems to happen fairly regulary on the lg VU
you can get it repaired or get a workaround external battery charger.
Check out the following link for your options.
http://www.chargemyphones.com/lg-vu-wont-charge/4/
Jul 02, 2009 | LG Vu Cellular Phone
My LG VU charges just fine sometimes, and other times it will say its charging and drain the battery, and other times it wont register that its charging at all.I have 2 house chargers, and one car charger...
well about the arrows being upside down, some phones like this one the charger goes in up side down like for example the katanas. But about the charging issue check in the back of the phone and look for a red or white sticker or maybe pink. if its red then thats indicating that it has been water damaged and if its white then that indicates that if might not be but if you look in the charge port and check if it has like some green and white corosion in it. If you would like some help with this just e-mail me at Purelatina2004@yahoo.com
Jun 15, 2009 | LG Vu CU920 Cellular Phone
Lg Vu wont charge
First you must determine is it the charger faulty or the phone ? , have you a friend with the same phone if so try her or his battery to see if your phone is ok if so try the charger with your battery and see if it charges if it does get a new charger , if it did not charge or work with your friends battery or charger the sorry it would be cheaper to buy a new phone than try to get it fixed ...
if you haven't got a friend with the same phone have a local electrician check if there is an output from your charger . if there is it may just be the battery try a new one if still no luck it is probably the phone's charger circuit gone pop ,, sorry .. vortash
May 13, 2009 | LG Vu CU920 Cellular Phone
Something is either work my my charger or the phone for the lg vu. a few days ago, the charger worked fine but for some reason its ot working but the red dot on the charger is on; when i plug it to my...
It is loose now the charging port may have gotten broken. It happens with the LG VU's.
If this is the case, you have 3 options.
1. repair -warranty preferably
2. new phone
3 or external battery charger. cheapest option
Check out the following link for more information
How to Charge LG Vu with Broken Charge Port
Mar 07, 2009 | LG Vu CU920 Cellular Phone
Battery charge
I agree that it sounds like you charger port is going bad.
The firststep is to contact your carrier to see if it is covered under warranty.If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.You can get an external battery charger to charger the battery separate from phone. cost about 25 dollars. Check out the following link for ones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
LG VU External Battery Charger Cradle
I hope that helps
Mar 01, 2009 | LG Vu CU920 Cellular Phone
Cell Phones Logo
162 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
