Question about Canon PIXMA iP4000 InkJet Photo Printer
I have an older Pixma iP4000 and a new PC with Windows 7. When I run the nozzle check pattern it shows that the print heads need to be cleaned. When I try to clean the print heads nothing happens. Then the nozzle check window pops up again. It doesn't matter, if it is a regular cleaning or a deep cleaning. How can I fix this?
    Scholar:
  • 135 Answers
Are you running Vista if so you may need to update the driver if they have one.
Posted on Nov 13, 2009
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
Suddenly stopped printing all colors. Will only
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
All of the ink cartridges are full, but the printing comes out very pink.
do the deep head cleaning for few times, it will drain some amount of ink but should work. After each cleaning check the printed nozzle pattern.
PS head cleaning is under printer properties-maintenance.
hope that helped
Jul 13, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
How do I print the nozzle check pattern?
Dear Sir,
plz flow this step for solve your probelm
These are the 2 important features for maintenance of your printer.
Nozzle Check
If your printouts are unexpectedly faint or have some missing dots or lines, it means that certain colour ink does not flow out nicely and consistantly. This is when you need to perform a nozzle check. If your nozzle pattern is good, then, your printouts will be good and nice as well. If your nozzle pattern breaks at certain parts, it means you need to clean the print head. Here's how to perform a nozzle check:
1. Click Start
2. Click Control Panel
3. Click Printers and Faxes
4. Right click your printer icon
5. Click Printing Preference
6. Click Maintenance
7. Click Nozzle Check
8. Click Print
9. Click Finish (if the nozzle pattern is perfect) OR
10.Click Clean (if the nozzle pattern breaks at certain places)
The following is the sample of good nozzle pattern and a bad nozzle pattern:
Good nozzle pattern:
Bad nozzle pattern (Head Cleaning needed):
Head Cleaning
Head cleaning is required when the nozzle pattern is not perfect. Usually, this action is needed when you have printed a lot or you have taken out the cartridge for refilling or for other purposes. Here's how to perform a head cleaning:
1. Click Start
7. Click Head Cleaning
8. Click Start
9. Click Print Nozzle Patterns (to check the ink flow after cleaning)
Thanks For Your Time,
Apr 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Have an iP90, but the color ink won't print.
When Printing Becomes Faint or Color are Incorrect, the Print Head Nozzles are probably clogged.
Follow the procedure below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
Print the Nozzle Check pattern to determine whether the ink ejects properly from the Print Head Nozzles.
a) Using RESUME/CANCEL button.
I) Ensure that the printer is turned on, and then load a sheet of Letter Paper.
ii) Hold down the RESUME/CANCEL button until the POWER lamp flashes twice, and then release it immediately.
b) Windows
i) With the printer on, load a sheet of Letter-sized plain paper in the printer.
ii) Open the Printer Properties.
iii) Print the Nozzle Check Pattern.
Click the Maintenance Option from the Menu.Then click Nozzle Check from the pop-up menu. Then click Print Check Pattern.
iv) When the confirmation message is displayed, click OK.
v) Confirm the nozzle check pattern.
Examine the Print Nozzle.
Step 2 : Cleaning the Print Head.
a) Cleaning the Print head using RESUME/CANCEL button.
i) Ensure that the printer is on.
ii) Hold down the RESUME/CANCEL button until the POWER lamop flashes once, and then release it.
b) If you pressed the Cleaning button on the Examining the Nozzle.
Check Pattern screen displayed after the nozzle check patter was printed, start the Print Head cleaning procedure.
i) Ensure tha that the printer is on.
ii) Open the Printer Properties dialog box.
3) Start Print Head Cleaning,
- Click the Maintenance tab.
- Click Cleaning.
- Select the Print Head to be cleaned, and then click Execute.
Print Head cleaning starts when the POWER lamp starts blinking,
Important : Do not start any other operations until the Print Head Cleaning finishes. This takes about 60 seconds.
4) Check the Print Head condition.
i) Click the Print Check Pattern in the nozzle Check dialog appeared after cleaning are done. When the confirmation message is displayed, click OK. A nozzle pattern will be printed. Do not perform any operation until printing is completed.
ii) Observe the printed nozzle check pattern to check the Print Head condition.
iii) If the problem persists after you perforned Print Head normal cleaning 3 times, execute Print Head deep cleaning.
Step 4 : Print Head Deep Cleaning.
If print quality does not improve by standard Print Head cleaning, try Print Head deep cleaning, which is a more powerful process and comsumes more ink.
1) Ensure that the printer is turned on.
2) Open the Printer properties dialog box.
3) Start Print Head Deep Cleaning.
i) Click the Maintenance tab.
ii) Click Deep Cleaning.
iii) Select the Print Head to be cleaned, and then click Execute.
iv) When confirmation message is displayed, click OK. Print Head deep cleaning starts when the POWER lamp starts blinking,
Important : Do not perform any other operations until the Print Head deep cleaning is completed ( about 2-3 minutes).
i) Print a nozzle check pattern to check the Print Head condition.
ii) If the problem persists, perform step 3 again.
iii) If the problem persists, the printer may have run out of ink.
Replace the ink tank.
iv) If the problem persists, the Printer Head may be damaged. Contact your dealer or Canon Customer Care Center.
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA iP90 Mobile Printer
Ip4000 printer prints but with horizontal lines
Cannon recommend a cleaning process called deep head cleaning
  1. Open the Printers folder.
    - For Windows XP select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
    - For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
  2. Right-click the printer icon and select 'Properties'.
  3. Click the Maintenance tab, and then click the 'Deep Cleaning' icon.
  4. Select the ink tank color(s) for deep cleaning ('All Colors', 'Black', or 'Color').
  5. Confirm the message, and then click the 'Execute' button.
  6. The Power lamp will blink and print head deep cleaning will start. Deep cleaning completes when the Power lamp stops blinking and lights. (It will take about a minute for the Power lamp to stop blinking and light solid.)
  7. Print a Nozzle Check Pattern by holding down the <Resume> on the printer until the Power light flashes twice to determine if further cleaning is necessary. Up to three deep cleanings may be necessary to determine if the print head is working properly
Sep 11, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I HAVE A CANON MP 760 PRINTER THE MAGENTA COLOUR LINE IS TWO TONED WITH DARK AND LIGHT PINK . SO WHEN PRINTING PICTURES THERE IS DISTINCT LINES CAN SOMEBODY HELP HAVE TRIED THE CLEANSING REPLACED THE...
You need to conduct the following steps:
The nozzle check pattern shows if each print head nozzle is operating properly.
You can also print the nozzle check pattern from your computer.
  1. Load A4- or letter-size plain paper in the Auto Sheet Feeder (ASF) or cassette.
  2. Press <Feed Switch> button to select the paper source.
  3. In either COPY, PHOTO, or FILM menu screen, press <Menu> button.
  4. Press the left or right arrow to select [Maintenance/Settings], then press <OK>.
  5. Use left or right arrow to select [Maintenance] and press <OK>.
  6. Use up or down arrow to select [Nozzle Check] and press <OK>.
  7. When prompted to print a nozzle check pattern, use the up arrow to select [Yes] and then press <OK>.
    The machine prints a nozzle check pattern
Print Head Cleaning / Head Refreshing
If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head.
MEMO:
a. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
b. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
  1. In either COPY, PHOTO, or FILM menu screen, press <Menu> button.
  2. Press the left or right arrow to select [Maintenance/Settings], then press <OK>.
  3. Use left or right arrow to select [Maintenance] and press <OK>.
  4. Use up or down arrow to select [Print Head Cleaning] or [Head Deep Cleaning] as necessary and then press <OK>.
When prompted to clean the print head, use the up arrow to select [Yes and then press <OK>.
IMPORTANT:
If normal print head cleaning does not improve print quality, perform deep print head cleaning.
Print Head Alignment in Windows
If colors mix or streaks appear in the nozzle check pattern, perform the print head alignment.
The print head alignment can be performed either automatically or manually.
If the automatic print head alignment does not resolve the problem, perform the print head alignment manually.
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Aug 09, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printer update
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head. NOTE:
  1. Press <COPY> or <PHOTO>.
  2. Press <Menu> repeatedly until <USER DATA> appears.
  3. Press < (left arrow) or > (right arrow) to select [MAINTENANCE].
  4. Press <OK>.
  5. Use < or > to select [CLEANING] or [HEAD REFRESHIN] as necessary.
    [CLEANING]: Performs normal print head cleaning.
    [HEAD REFRESHIN]: Performs deep print head cleaning.
  6. Press <OK>.
  7. Print a Nozzle Check Pattern to see if print quality improved.
    4. Press <OK>.
    5. Press <OK> again.
      The machine prints a nozzle check pattern (A).
  8. If broken or white lines appear in the pattern, perform two Head Refreshings (from steps 1 through 6) then print another Nozzle Check Pattern.
  9. If print quality does not improve after two Head Refreshings, replace the appropriate ink tank.
Confirming The Nozzle Check Pattern
Broken lines
sj402061.jpg White lines
sj402062.jpg Click here to return to step x to perform Head Refreshings
Oct 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA iP4000 InkJet Photo Printer Logo
193 people viewed this question
old marine
old marine
