Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
My lawn tractor has had a problem needing to choke it several times to start it and after trying it several times, it would only click. The battery is new. I am trying to do my thing and was told it could it could be the solenoid. Where do Ifind it to start there? Thanks
  • 486 Answers
Try the easiest things first.
1) jump start with your automobile
2) check to see if starter is free
a) *with your hand, turn the flywheel screen on top of the engine
b) connect the jumper wire to the cable post (positive or red cable)
connect the negative to the battery
*NOTE: many times the starter gear can become locked into the flywheel, and the battery is not able to overcome, and you will hear a click from the solenoid.
3) If #2 works, then replace the solenoid
Posted on Nov 13, 2009
Why is my Craftsman lawn tractor so hard to start?
Most likely needs valves adjusted. If you can give model number off of the engine, i can try to find the manual or instructions on how to do this for you.
Jun 28, 2014 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Riding lawn mover with new battery but doesn't start.
When was the last time had valves adjusted.
Jun 26, 2013 | Craftsman Garden
Hello folks; My Husqvarna yth 2348 rider is very hard to start on the initial start. After once getting to run, it restarts easily with little hesitation or need of choke usage. Help please on how to start...
Sounds like your choke cable needs adjustment. Follow the choke cable to where it mounts on the carb.
Move the choke lever at the same time watching where it mounts to the carb. there is usually a clamp holding the cable in place, you may need to loosen the clamp and slide the cable back to make the choke fully close
Aug 30, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have not used my lawn tractor for a long time. now it just CLICKS when I try to start it.
battery does not have enough charge to spin the starter, you might be able to charge it up. try jump starting from a car battery then mow your whole lawn without stopping. if it restarts after that you are good to go, if not go to walmart and spend 25 bucks on a new battery. replace the gas first.
Apr 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I charged the battery and there's gas in my lawn
Usually there is a combination choke on the throttle, when you put the throttle all the way up it sets the choke and once the engine fires you idle it downa little to full throttle.
Apr 09, 2010 | Garden
Lawn mower stays running on jumper cables but once disconnected it shuts down when choke is engaged
if it is already running and you "engage" the choke, you will flood the engine with too much gas and it will sputter and die. the only time you engage the choke is to start the engine when it is cold. if the mower dies when you remove jumper cables, and you leave the choke alone, you need to have someone look at your charging system.
Apr 08, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
10 year old Craftsman Lawn Tractor won't start
That's really strange. The low-speed fuel adjustment screw may be set way too rich, but that doesn't seem likely. With the air filter off, look at the choke plate if possible as you advance the throttle and see at what point the choke closes. Back it off till the choke opens and then put the filter back on and try to start it at that setting. Another thing that could cause too much fuel is if the adjustment of the carburetor float is off, causing the fuel level to be too high in the carb bowl.
Aug 03, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Choke stuck
You may have to replace the choke cable assembly. Sometimes they rust to outer sleeve
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
247 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
