Question about Goodman GMS90703BXA Heater
Have a goodman furnaec and has a control prob what could be causeing it
  • 3,600 Answers
It's most likey a control freak try replaceing the contrl freak to see if this helps, otherwise replace the contor freaks thermostat that may fix the problem. If you need more help give us some more information, don't want any control problems around here to.
Posted on Nov 13, 2009
3a fuse blowing on the blower motor board
The 3 amp fuse blowing indicates some control function is either grounding out (probably a worn insulation on control wire) or one or more of the solenoid controls is pulling more wattage than it is designed to draw. The solenoids for the main contactor and reversing valves should only draw about 0.1 to 0.25 amp. Any more than this the solenoid overheats and causes the control fuse to blow. I have actually had to replace the thermostat wire on some units because the control that was pulling more than designed caused the entire length of thermostat wire to overheat and break down the insulation, causing the control wire to short to the common wire or others and cause more than required operations to occur simultaniosly. One unit had a short and emergy heat was coming on the same time cooling was on.
Feb 23, 2014 | Goodman Manufacturing Goodman GPH1348H41...
The inside control for my goodman ac unit is not working
digital thermostats often use batteries some installers do not connect the common wire which will cause the thermostat to go blank when the batteries run down. unsnap the face of the thermostat off and replace the batteries
Sep 02, 2013 | Goodman Heating & Cooling
Goodman furnace fan runs all the time
Hello, this can be caused by a bad relay on the integrated control board or a short in the low voltage wiring. Easy way to check is unhook the green wire from the G terminal on the control board, if it stops there is a short in tje wiring, if it does not stop the control board must be replaced due to a bad relay.
Oct 28, 2011 | Goodman GMS90703BXA Heater
The ac does not resond
First you need to check the power going to the unit, check to see if the breakers are on.
I f you have power go to the thermostat and switch the fan switch to on, if it does not come on you have a low voltage prob
If it does, then you have a prob in unit....I need more info
Jul 25, 2009 | Goodman Heating & Cooling
Is a patriot heater comparable to a goodman heater
The Patriot 80 is an oil furnace made by heat controller, To my knowledge Goodman (aka AMANA) does not make an oil furnace.
Feb 23, 2009 | Goodman GMS90703BXA Heater
1995 Volvo 960 idles rough, Emission Control light on dash is on
Possible intake gasket leak causing a misfire, or plugs or coil causing a misfire. each cylinder has its own coil. You can hear the vaccuum leak with your ears under hood if gasket is bad. Check eng codes at advance auto prob for free. If it has misfire codes only, prob coil or plugs. If misfire with fuel trim, prob gasket.
Oct 23, 2008 | 1995 Volvo 960
Goodman GMP125 - 5
it could be a broken wire or bad control board.A popped roll out switch could cause this also
Aug 06, 2008 | Goodman Heating & Cooling
Goodmans ld3750hd
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the problem with the component that mentioned by you, write down the Number written on that and replace it with the same by the help of a Soldering Iron.
Also see the writing near to it for finding out what the component is.... For eg. C=Capacitor, R=Resistor, TR or Q=Transistor, IC=Chip, D=Diode etc.
Apr 13, 2008 | Goodmans 257NS 20" TV
Crashed
no probs..jus get it serviced...format ur pc once...every thing will be ok...
Oct 09, 2007 | Goodmans GMP32000 MP3 Player
Goodman GMS90703BXA Heater Logo
98 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
