Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
My Dryer portion of my GE stacked washer/Dryer will turn on and I can hear the motor running but the drum will not turn. I pretty sure is the belt. I haven't been able to locate a schematic anywhere of the Dryer showing the belt. Is this something pretty easy to change? I'm very mechanically incline and have worked on washing machines before.
  • neil_diego Nov 13, 2009
    Thanks for the quick reply. However I was on your suggested website and it doesn't show or offer the belt.
    Can I open the dryer from the front or do I have to access through the rear? The stacked washer/dryer is wedged in a tight closet which makes reconnecting the plug, vent, and water lines a b****!
    Scholar:
  • 135 Answers
Yes Open the dryer up to where you can see the belt.Then replace with a new belt.
Posted on Nov 13, 2009
  • 3,600 Answers
Not that easy but go to this web site www.applinace pros.com and look at it's diagram and you can see if you want to tackle this issue, if you do and rn into problems you can get help from us here if you need it.
There is a belt sitting in the washer at the base of the tub and what appears to be a small white plastic piece between the alternator and motor is this where the belt belongs
i no expert on that model but i seen a few inside of a washer there a moter small siver thing the belt goes on there and around the drum i say the plastic thing is part of the cog for the moter but cant be sure without seeing it does the drum spin or move when turn it on if not then that defo the drum belt
Apr 04, 2012 | Whirlpool LTE5243D Top Load Stacked...
Dryer will not turn on
if u have recently replaced the belt, the drum may have come out of the track. i suggest taking it apart and making sure the drum is seated correctly. i had to do this several times to my mothers ge electric dryer.
Nov 15, 2011 | Frigidaire FGX831CS Top Load Stacked...
Dryer is froze(drum)
if u can hear the motor turning but the drum is not you need to replace the belt around that gos around the drum
Feb 27, 2011 | Whirlpool LTE5243D Top Load Stacked...
Dryer drum does not turn.
If you can hear the motor turn on, but the drum does not turn, it's probably a broken belt.
If you CAN'T hear the motor turn on, it could be the timer, the motor or safety controls.
Feb 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
I push the start button and the dryer makes a humming sound and the drum doesn't turn nor does the dryer turn on
Humming indicates motor is getting weak. If you look in the back compartment of your dryer you can probably see the belt. You can relieve the belt tension and then take the belt off the motor pulley. Once you do this, make sure the belt is out of the way and push the start button. If the motor turns it means it couldn't push the weight and is too weak to run. It make not turn without the belt on it either but you will hear if the sound is coming from the motor. In either case you need a new dryer or new motor if the dryer is pretty new.
May 02, 2010 | Dryers
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Squeaky Belt when dryer is running. However the dryer is working (heating) fine
Very possibly not the belt but the associated components like the drum: motor bearings bearing strips support:rollers (if you have them) etc. Truthfully i would just continue untill something malfunctions then do an extensive repair. Once you start repairing these small ****, it esculates into a relatively large expence.
Sep 23, 2009 | GE WSM2700D Top Load Stacked Washer /...
Kenmore dryer
Are you getting heat and can you hear the motor running? If so then you've just had a belt snap. It's a pretty easy fix. You just gain access to the dryer through the back. Remove the several screws that hold the back pannel in place. You will most likely see the broken belt as soon as you remove the panel.
A new belt is very inexpensive! Good luck!
Dec 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
My dryer stopped working -- won't turn and motor makes odd noise like not engaged properly
go to back of dryer should be a panel on back of the drier pull it off and check the belt
Dec 29, 2007 | Maytag LSE7806A Top Load Stacked...
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
180 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
