Question about Kwikset Professional Door Lock installation Kit
How do i remove exterior handle kwikset titan?
    Novelist:
  • 160 Answers
You need to insert the key and turn it clockwise, then insert a stiff metal tool like a straightened out heavy paper clip into the hole on the shaft of the lock by the circular flange next to the door. Push it in until you feel it give and pull out on the handle at the same time. If you need more help please contact me.
Best of Luck,
RSMITH972278
Posted on Nov 14, 2009
Using a putty knife or similar device, pry round cover plane away from the door skin. Protect door finish with rag or thick paper. Behind cover plate are the elusive screws binding the handle to the door. Remove screws and separate the inside from the outside of the door.
Posted on Mar 03, 2018
How do I remove the 10-year old "TITAN", locking dead bolt from my front door? I removed the interior turn-handle side, but can't get the outside (keyed side) off?
if the inside is off and you unscrewed the main long throught the door screws than it is more than likely just stuck on by paint, they clamp to the door from each side with those screws, if there a no visible screws then its just stuck
Oct 16, 2014 | Kwikset Titan Single Cylinder Deadbolt
How do i manually retract - Exterior door stuck closed - removed knobs (levers)
PUT A SCREW DRIVER IN THE HOLE AND TURN IT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/joe_0ca6379e2eceb740
May 25, 2014 | Kwikset Lido Polished Brass Entry Lever...
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
I have an exterior screwless doorknob that I need to remove. The faceplate on the inside knob that covers the screws is also covering the little pin that removes the knob. Is there another way to remove...
There is the 3rd version of the Kwikset exterior door set. The interior face plate is removed and on each side of the base plate has small slots with a lever on either side that need to be moved to the other end of the slot. The whole interior knob assembly with come off.
Dec 23, 2011 | Kwikset Locks & Locksmithing
My exterior door lock (Kwikset) is stuck shut. The knob will not turn. I removed the knobs and tried to pull the mechanism back - but unable to. The door is therefore stuck shut.
Get a big scredriver and put it in the square in the middle of the mechanism and turn it till it opens, or you will just have to pry it out with the scredriver.
Apr 05, 2011 | Kwikset Locks & Locksmithing
Exterior key for deadbolt just turns around and around.
It sounds like the exterior tumbler is bad, it is less expensive to just replace the whole deadbolt than to have the tumbler repaired.
Jun 15, 2010 | Kwikset Professional Door Lock...
Replace left front door outside handle pot metal tip broke off
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual REMOVAL AND INSTALLATION Exterior Front Door Handle Removal and Installation
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
  1. Position the watershield aside.
  1. NOTE: The tie strap does not need to be reinstalled.
    If equipped, remove the tie strap from the anti-theft guard.
  1. Remove the screws and position the anti-theft guard aside.
  1. Release the clip and disconnect the exterior door handle actuating rod.
  1. Remove the anti-theft guard.
  1. Remove the exterior door handle screw.
  1. Remove the exterior handle actuating rod.
  1. Remove the exterior door handle lock cylinder cover.
  1. Remove the exterior door handle.
Apr 25, 2009 | 2001 Ford Escape
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Kwikset Professional Door Lock installation Kit Logo
3,341 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
