Question about Linksys Wireless-G Broadband Router
After a windows update on 11/5, my wireless-g stopped working. Re-boots proved unsuccessful and I can connect via cable thru the modem. Any ideas? Thanks
  • 329 Answers
Make sure that wireless driver are installed properly and its working fine
Posted on Nov 14, 2009
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
D-link DSL 2730u modem dead after wrong firmware update through wireless
Attempt to do the firmware update, again--connecting always to ethernet for firmware updates. Unfortunately, your modem may be "bricked" (unusable)--in other words, it may be time to recycle it and buy a new one.
The firmware may proved damaged--given that the incorrect firmware successfully installed (hopefully, that was prevented by the device itself--it may have output an error message or code)--or, it was installed incompletely, or the update proved corrupted.
Mar 25, 2014 | D-Link ADSL2/2+ Modem/Wireless Router...
Hooking up wireless router to phone jack
Please add a comment with your router model number and the type of network service that you have.
Most routers need to be connected to a modem that connects to the outside line. (Depending on your service, this could be a DSL or cable modem or a unit that connects to a phone.)
For a wired incoming network:
You connect your RJ-11 (phone cable) to the appropriate-sized port on the modem. Then connect a RJ-45 cable between the modem and your router. Then connect any wired devices via additional RJ-45 cables (many routers include a four port switch). A few have a USB connection option for one computer; most with USB ports have the other type of USB connection for sharing a hard drive or printer. Use one wired connection to set up the router, including your encryption and password to secure your wireless network. (For some ISPs, you'll need to do some extra setup, including programming your username and password. This is usually not needed for DHCP connections, where the IP address is dynamically generated.) Finally, use the encryption protocol and password to set up the wireless network on your wireless devices. (Under Windows, go to the Windows Network control panel and choose Add New Network. For other wireless devices, you'll need to find a similar setting.)
There are a few modem/router combination units. However, those are less common. They will have both the RJ-11 and RJ-45 ports. This is for wired networks. For the devices that let you share your cell phone's network, you will probably see a USB port of some type on the unit.
I hope this helps.
Mar 12, 2012 | Computers & Internet
Can't establish connection by cable
Assuming you would have checked your LAN port. Try using a USB LAN port device and see if it picks up. Else you can test connecting the modem via Ethernet cable to another machine. Does it work,? If it does then its your machine.
Apr 11, 2010 | D-Link DIR-300 Wireless Router
Wireless not working
Need more information.
1) Make & model of router and/or modem
2) OS and Version (ie. Windows XP or Windows 7 ect.)
Feb 10, 2010 | Arris SURFboard SBG900 Wireless Router...
I have a cable connection to the internet and when I hook up the
1. Disconnect the cable from your cable modem and connect it to one of the four on the back of the wireless router.
2 Connect a cable from the back of the cable modem to the LAN port on the wireless router.
3. disconnect the power on the cable modem for about 30 seconds.
4. reconnect the power to the cable modem and wait until the unit boots completely.
all but the activity light should be on.
5 power up the router and wait a few moments.
You should now have access on your computer that you have connected to the router. verify this by going to a web page.
6. on the laptop, open the control panel and then the network connections control panel (this assumes we are working with windows).
7. Highlight the wireless adapter by clicking on it once.
8. To the right of the icon will be a list of links. (assuming windows XP). click the one that says "view available wireless networks". Your router should be in the list. If so, highlight it and click connect at the bottom of the window.
Did this resolve your issue?
Apr 05, 2009 | Linksys Wireless-G WRT54G Router
Buffalo WHR-G54S & Virgin Media
Just to let you know if you havent solved it yet, i had this same problem today and i fixed it by pressing the reset butoon on the modem, this was after hours of trying to reset the router
Mar 20, 2008 | Buffalo Technology WHR-G54S Wireless...
HELP PLEASE ASAP
OK well I think it is better to set it up like this... Connect the Modem to the Phone Line, Connect the Modem to the Router with an Ethernet Cable, Use a CABLE connection from the Main PC to the Router. (Ya gonna ditch the USB WiFi) Set that Main PC connection up to connect to the internet from the Main PC, thru Router thru Modem.... Then from Slave, install the USB adapter in this PC, and use this to connect DIRECTLY to the WiFi Router... and thus to the internet. This way will give the best transfer rates, and reliability
Sep 15, 2007 | Actiontec GT704WG Wireless Router...
Linksys Wireless-G Broadband Router Logo
50 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
