Question about Acer AL2416W 24 in. LCD Television
Turn on and acer flashes on screen then goes black, sometimes if you press on/off many times screen comes on and is good for about a day
I found C34, C35, C36 and C38 (all 100uF 35V) caps with their bottoms blown out due to over voltage. I suspect Q4 and Q6 to be the culprits. They are both short circuit. F2 found open circuit.
All of the above are found on the backlight inverter PCB.
My problem is sourcing Q4 and Q6. No data available on these devices.
Any help would be appreciated.....
Posted on Mar 12, 2010
  • 11,361 Answers
The backlight inverter board may be going out, or bad power supply for the inveter is bad. Look at the power supply module fist since it is easy to get to.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 13, 2009
Windows is not loading have black screen with white cursor then goes to acer and fast out again to white cursor
Hello, doing a "last known good configuration" Works most of the time. Here is how to do it:
1. Make sure your computer is powered down.
2. Turn your computer on and immediately start pressing F8 on your keyboard repeatedly until you see a black screen with white writing that gives you a list of boot options.
3. Use the down arrow on your keyboard to select the Last Known Good Configuration (Advanced) option.
4. Press Enter on your keyboard and cross your fingers.
Good Luck!
Mar 31, 2011 | Acer Computers & Internet
ACER screen goes black after a few minutes of being on. I then close the laptop then log on again and the screen comes on then flickers off back to black, can very faintly see the desktop in the back...
Hi. This might be an LCD issue or connector inside th LCD from the motherboard is loose. You may try troubleshooting the issue first before you send the computer for repair. This process will drain the remain electrostatic energy to your motherboard which sometime causing the issue. Please follow troubleshooting steps below.
Take out the battery and unplugged the power adapter
Press and hold the pwoer buttong for 30 secs
Put everything back in
Power ON the computer
have a good one!
Jul 29, 2010 | Aspire Acer 7520-5071 Notebook
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Monitor comes up shows "acer" then says no signal and goes black
This Problem is Acer(s) Monitors. Though it is a nuisance one fix That has work for many is the Unplugging after it goes back to Good (viewable) screen.
I have hooked mine up to an inexpensive Power strip to make it easier for me and just turn off at time indicated above and Viola Simple is as Simple does :)
Apr 24, 2009 | Acer X241Wsd Monitor
Black screen after windows xp screen nothing else
Sometimes the function keys get depressed by accident and it takes away your display. Press the FN+F5 and FN+F6 three times each and see if your display comes back on.
Dec 27, 2008 | Acer Aspire 1640Z Notebook
LCD Monitor wount turn on Black screen
my Acer AL1716 monitor will not come on after pressing the on button and no green light.
Aug 25, 2008 | Acer AL1716B 17" LCD Monitor
It's not working!
It seems to be a software failure. Try using your recovery CD to sort it out. If it continuous then i would recommend a clean install if there's nothing that important on your laptop.
-Aaron
Aug 08, 2008 | Acer Aspire 3680 Laptop
My moniters screwed
Sometimes this is due to graphics cards, but most of the time it is due to drivers. If it does not happen when you are using your PC for other things the problem probably just lies with the graphic card, driver, and this particular game or any game similar. Drivers are the most notorious! Check your requirements on the game for graphics cards recommendations! Let me know!
Oct 10, 2007 | Acer AL1916W 19" LCD Monitor
My Acer Aspire 3000 has a blank screen
When you get in setup check the time and date and see if correct, if not; correct it and save settings and exit, then it should reboot. If the time is correct and date then you will have to reboot the system and keep pressing F8 while its booting, this will take you into safe mode, you need then to choose last known good cofiguration and hit enter, hopefully you should now get into windows.
Sep 05, 2007 | Acer Aspire 3000 Notebook
Acer AL2416W 24 in. LCD Television Logo
1,152 people viewed this question
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
