Question about Ricoh Aficio 450 Copier
I have a 2045e copier that I moved from one area to another. Now it gets error code SC545. How do I clear the code.
    President:
  • 1,126 Answers
Press 'Function Clear' button, then '1' then '0' then '7' then press and hold 'Stop/Clear' button. The display will change to 'SP' mode. Now shut off the main power switch on the left side....wait 5 seconds with power off. Turn machine back on. If the code reapears, your Fuser Unit needs serviced.
Posted on Nov 13, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The thermistor is out of position or something is obstructing it. Turn the copier off and press online and escape buttons. While pressing these keys, turn on the copier and wait for about 1 minute and service menu will show up then release these keys and go to Engine Maintenance -> Enter -> Search for SP5810 fusing error clear -> Enter. Now accept the changes -> enter. Now turn the Copier off. After 2 minutes turn the copier on and try to copy a page.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
I have an sc 326 error code in my ricoh aficio 2045 copier
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
Functional Problem within copier, code SC545
The error code 545 or SC545 means that the fuser, also known as the fixer assembly has a thermistor problem (this part melts the toner onto the page). It could also mean that the fusing lamp is disconnected.
If a simple reset of the of the error code does not work ("Clear Mode"+107+"Clear/Stop" hold for 5s. Turn ON and OFF the Main Switch) you may need to have your machine serviced by a professional. It is your best bet to also have standard cleaning maintenance done by your on site technician after fixing the error.
Jan 14, 2012 | Gestetner DSm735 Black and White Copier
Error sc545, how to solve?
sounds like you have a fuser error code to reset hit clear modes (yellow button) 1-0-7 then the clear (orange) button continue holding down until screen changes once you are in .. turn copier off.. if there is nothing wrong the problem should go away. if there is another problem with copier it will come back make sure everything is closed all doors and covers and the fuser is pushed all the way in.
Dec 28, 2010 | Ricoh Aficio CL7200 Laser Printer
Error Code of SC545
That code will not reset by powering off and on. It needs to be reset in the service mode.
Jun 16, 2009 | Ricoh Aficio AP410N Laser Printer
This is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
Apr 09, 2009 | Ricoh Aficio 2022 Black and White Copier
I have a Ricoh 2045E I changed the toner and now get a SC680 error?
There are no SC 680 codes listed in the service manual for a 2045e
Please re check the code
Feb 26, 2009 | Ricoh Aficio AP3800C Laser Printer
REX ROTARY DSM618 D SC545 ERROR CODE
you have to go into the sp modes to clear this code .pres the yellow c then 107 and hold down the orange c , do this all in sequence , it wil go in the sp modes and show copy sp .enter there and switch the power off wait 5 seconds switch back on
Jul 18, 2008 | Gestetner DSm515pfd Digital Copier -...
Ricoh Aficio 450 Copier Logo
194 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
