Question about Ryobi 18-inch Electric Chainsaw Chain Saws
Broken switch. How to get a new one - Ryobi 18-inch Electric Chainsaw Chain Saws
  • 3 more comments
  • sga7418 Nov 16, 2009
    Many thanks for your request.
    Model Ryobi ECS-2040
    16 in
    I have some problem reading 2 first chars in serial no.,but most likely it is: AG 1838/05 or RG 1838/05.
    I hope a new switch will solve my problem. I have repeard it will glue but it will not release proberly now. (A litle bit danger involded by using it since I have to remove the wall connection to stop the saw)
    Thank you for your reply.
    No solution so far cause my model number (ECS-2040) and ser.no (AG1838/05) dont match the required format for model (00XX000X000) and for serial (0X000X00000) where X represent all letters and 0 represent any number and/or dashes
    Hello again Sir. I can now see that my model is a 16 in. I cant found anything about the 16 in model on net. Maybe like cars. Different models are shipped to different countries. This one is baugth in Norway.
    Hello Sir.
    Any way thank you for phone number. I rank yot at top for that.
  • Roland W VanLue
    Roland W VanLue May 11, 2010
    model numbers please
My Znen 250cc Scooter has a broken turn signal switch. Can you just replace the switch lever?
if the switch is broken there would be little point in just replacing the lever
new switches will come with a new lever
Nov 14, 2016 | Cars & Trucks
Won't turn on 1222se
if the switch is broken then the machine needs to be taken to
a sewing machine shop to have a new switch put on.
Jul 30, 2012 | PfaFF Sewing Machines
Brake light switch wires broken
Here is a picture of the brake light switch. Also at this point just buy a new connector and splice it on, much easier.
Jan 15, 2012 | 2000 GMC Sierra 3500
Where can I get a new ignition switch? The ignition key has snapped off in the switch, and I can't start the bike
You may not need a new ignition. Take the bike to a locksmith where they should have a broken key extractor tool, and then have them cut a new key from the broken piece of the key. It should not be too difficult for them.
Jun 22, 2010 | 2002 Sachs XTC Racing
Broken on/ off switch for rockworth ARPD1700 hammer drill
rockworth powertask demo hammer needs new trigger how do i get parts
May 17, 2010 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
97 expedition new window motor and switch still don't work
You have to use a voltmeter and make sure the motor is getting power. If no power at the motor, check for power at the switch, first make sure power is coming into switch, and then operate the switch and make sure power is going out to the motor.
Make sure you have a good ground on the door.
Could have a broken wire between switch and door, or between fuse block and switch. A wire can be broken on the inside without the insulation being broken
Jun 10, 2009 | 1999 Ford Expedition
Broken light switch on fridge door
Any appliance parts store can get this switch.
Yes you can DIY. Take a butter knife and CAREFULLY pry the broken switch from the cabinet. Be careful not to scratch the plastic liner around the switch.
Remove the 2 wires, place them on the new switch and POP the new switch in place.
If this is a half-moon switch make sure it is installed in the correct direction.
May 24, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Broken Toggle switch
A toggle switch is a common item. Remove the broken one and take it to a hardware store where they will match it up so u will have the new one u need.
Apr 29, 2009 | FrancisFrancis! X1 - Stainless Steel...
Broken on/off switch
need to replace the on/off switch for this camera. I have the broken piece that cannot be repaired. How can i find a replacement switch. I can repair the camera myself with the new switch. thanks.
Jul 19, 2008 | HP Photosmart M425 Digital Camera
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
73 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
