Question about Toshiba REGZA 26HL47 TV
I have a rented DVD stuck in a Toshiba 26LV46 built in unit, no function of the unit. Any way to get the DVD out?? The distorted image is stuck on the screen..........help
  • 1 more comment
  • berkeleymana Nov 13, 2009
    By stating "take the set apart", are you saying remove
    the DVD player because it does not appear that is an option. There are seven screws around the rear edge of the set.......?
    Thanks, one last question, how long should it take to complete, & what would be the typical $$ charge be for this?
  • berkeleymana Nov 14, 2009
    The information was very helpful, thank you.
    President:
  • 1,284 Answers
Try unplugging the set for at least 2 minutes then trying the eject button again. If that doesn't work then you will have to take the set apart and manually extract the disc.
Posted on Nov 13, 2009
Testimonial: "Technician very succint in resolution of the problem."
  • 1 more comment
  • Don
    Don Nov 13, 2009
    Yes, the only way to get to the DVD player is by taking off the entire back of the TV. It sounds tough but not too bad although I suggest taking it to a TV technician to remove the disc for you. You can then replace the defective DVD drive if it still doesn't work. Here is a link for a site to order the DVD drive from...
    http://www.partstore.com/Part/Toshiba/To...
  • Don
    Don Nov 13, 2009
    From my experience on working on these combo TV/DVD's it shouldn't take more than an hour of a technicians time. The cost will depend on their hourly rate. Shop around for the part and see what the lowest cost you can get it for. The reason I say that is you won't have to pay a shops mark up for the DVD mechanism is they order it for you. I hope all of my information helps...
  • Don
    Don Nov 14, 2009
    Please don't forget to rate my response as it is much appreciated. Have a great weekend.
Negative image from lcd toshiba
You must first try to check the setting of your lcd tv if the features are set properly. Go to picture adjustment then you will see AV format select the negative function this setting will display the image correctly without distortion or picture clipping.
May 14, 2011 | Televison & Video
I have a dvd stuck in a toshiba tv dvd combination
Try a reset on ur tv,Like unplug ur tv an hoour.Replug it back.Should get power to the DVD port to take out the DVD disk.
Feb 08, 2010 | Toshiba 23HLV87 23 in. LCD Television
My laptop screen started to look like an old tv with a distorted image. The colors look different, and there are pink and red lines going across. The laptop seems to function o.k. but the image is...
This definately is hardware issue.
2 options for you.
1. open the screen and check if the signal cable to lose. if you can out it in right place you can fix this onyour own.( I would recommend this only if you have prior experience in troubleshooting laptop hardware)
2. otherwise see the hardware vendor.
Sep 09, 2009 | Toshiba Satellite A100-S8111TD Notebook
A DVD is stuck in my player. When I open the tray the dvd isn't in it. I can see the dvd inside the player but it will not drop on to the tray. HELP! ITS A RENTED DVD!
Try removing the top cover, very often if the DVD is not in the tray it will be accessible to retrieve once the cover is removed.
Aug 04, 2009 | Toshiba SD-2900 DVD Player
DVD/VCR Combo Stuck in VCR Mode
i could probably walk this one through chat at idahoredfoxusa@yahoo.com
Jun 04, 2009 | Toshiba SD-V394 DVD Player/VCR
Two DVD's stuck in Toshiba Regza with built-in DVD player
If you can find a piece of stiff wire, put a small 90 degree bend onto one end and try to hook the edge or middle of the DVD drawer and pull out the drawer. It will resist a bit but should come out.
Jun 01, 2009 | Toshiba REGZA 47HL167 TV
Stuck dvd in sylvania tv combo
ok this is a verry delicate procdure so do this with caution. take the tv and huck it out the window!!!!! that get that #%&#@# outa there hahah jk. ok so just take some plyers and pull the cd disk tray out with them slowly it may cause damage to the disk but just go slow and steady and it wont break the tv
Jan 31, 2009 | Toshiba MD20P1 20 in. TV/DVD Combo
DVD stuck in tv combo unit
Had same problem! Husband took back off tv, lots of screws, unscrewed the dvd player and turned it over. There is a white wheel, turn that slowly. It opens and closes the dvd "tray". He turned it until DVD came out. Tried another DVD but no good. Had only used the DVD once since owning tv. Won't use it again.
In the past we would not buy combo units. Won't ever again!!!!
Jan 31, 2009 | Westinghouse SK-32H590D Television
Sony SLV-D300P Video Distortion
Have you tried pressing the progressive button on the front panel of the player?
Mar 27, 2008 | Sony SLV-D300P DVD Player/VCR
Toshiba 20hlv15 image turns bright colors and will sometimes disappear.
I took the unit completely apart and reassembled it, making sure to check all harnesses. I have been running the TV since I put it back together and it has been fine so far (3 hrs.). I was hoping that it was just a loose harness4.gif when taking the unit apart. Although, I did not note a loose harness. The dvd1.gif player went wacky by just having the harness slightly off. I will run the unit some more and post my findings. I have to say I'm surprised that this is not a more common problem considering there are numerous people with this particular unit with the same issue. Also, just a note the unit was very clean inside, no dust issues, no blocked cooling ducts.
Feb 05, 2008 | Toshiba 20HLV15 TV
Open Questions:
See all Toshiba REGZA 26HL47 TV Questions
Toshiba REGZA 26HL47 TV Logo
283 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
