Question about Maytag MDE2600 Electric Dryer
Dryer will not start - have check the start button and that is ok. When you press the button it just make a clicking noise but the dryer will not start
    Scholar:
  • 135 Answers
Check the dryer door to make sure that the small switch is not broken.
Posted on Nov 13, 2009
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
After doing a few cycles the dryer would not turn on. Pressed the start button and it made a buzzing noise 2-3 times then no noise at all. After letting it cool, took the dryer apart, cleaned it out and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 12, 2011 | Dryers
Kenmore 64112 dryer wont start when I hit the start button
Check house fuses or circuit breaker.
Pull 220V cord from wall outlet and inspect the gold prongs.
If you see any burnt areas on the prongs the outlet is bad.
If the unit makes no noise when you press the start button check the dryer door switch and make sure it clicks when depressed.
Sometimes the door switch arm can break off so when the door closes
the door switch cannot be activated.
If you hear a growl noise when you press the start button 2 things...
1. The motor is bad and needs replacing.
2. An object fell down the lint trap and is preventing the motor from turning.
Also if the dryer vent has been plugged causing the dryer to over heat a saftey fuse may have blown and needs replacement.
Jan 16, 2010 | Kenmore 64112 Electric Dryer
My Maytag dryer started making (from what I have read, the famous) rumbling noise. So, I went to see if the blower wheel. It looked ok. Now, when I press the start button, the drum doesnt want to turn. ...
THAT NOISE IS FROM THE EITHER THE BELT PULLEY BEARING OR THE ROLLER BEARING. YOU MIGHT HAVE 2-4 OF THEM, DEPENDING ON THE MODEL. CHECK THE PULLEY, MAKE SURE THE BEARING IS OK, YOU CAN REGREASE IT. WHEN CHECKING THE ROLLERS, MAKE SURE IT TURNS FREELY WHEN YOU SPIN IT AND THAT THE RUBBER IS NOT DENTED OR WORNED.
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH THE PROCESS IF NEEDED.
Jan 14, 2010 | Dryers
I have a Kitchenaid Duet dryer. When I press the
you dont say how old it is.but what your discribing i would not use it until you get it checked out i would say the moter is burnt out.adrian;;;
Nov 11, 2009 | Vacuums
Dryer will not turn on although the timer is working
IF your hearig a click when you push the start button then the button and relay are good check the saftey switch on the door to see if it has come loose and follen down or moved back if the switch is not pressed the motor will not work also I have seen the switches go bad you need to unplug the dryer and cross the too wires togeather plug the dryer back in and press the start button if she starts order a new swith. The motor could also be bad you nees to remove the back cover and check to see when the button is pressed if you are getting the correct voltage you will need a volt meter to check this they cost around 10- 20 bucks if you have correct voltage from the wires and the conections to the motor are ok the motor is no good and needs to be replaced hope this helps...
Jul 07, 2009 | Kenmore Dryers
Kenmore dryer won't start
check the door switch,see if it is clicking,if ok remove the back panel and check the main fuse on the blower box,let me know what you find-mike
Apr 07, 2009 | Kenmore 63942 Dryer
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Maytag MDE2600 Electric Dryer Logo
198 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
