Question about Orange Coast LED Lenser LL7555 V8 Standard Torch bright LED Keychain flashligh
I have aCOAST flashlight 3 LEDs, Silver in colorand 3 LR1 batteries. Light is 5.5" long. Bad switch. Can it be repaired.
  • 863 Answers
Yes.  Switches are cheap.  Go to Radio Shack and they will hook you up with the switch, some solder, and a solder tip.
Posted on Nov 13, 2009
Repair for Innova GT 3 led, 3 AA battery flashlight.
Before doing serious damage, check for a poor ground to the case. I have worked on a couple of these and some of the manufacturers seem to believe a solder connection to an anodized aluminum case is going to work. Use a tool with a sharp point to scratch through the anodized layer to expose a clean metal ground. You may have to repeat this from time to time as the light fails.
Aug 26, 2016 | Camping, Backpacking & Hiking
Stanley flashlight keeps blinking like a strobe light how can I fix it
I assume it is an LED flashlight (you did not say). Cheap Chinese-manufactured LEDs will flicker in this way when they go bad. The condition is not repairable... you will need to replace the flashlight. (Save the batteries.)
May 11, 2015 | Stanley Camping, Backpacking & Hiking
My flashlight will not turn off
This is what i did to make it work (by pure guesswork).
1. take the battery holder thing out.
2. see black arrow on side of battery holder, that needs to point toward the led end when you insert it.
3. Look at the end of the battery holder, at the end that will go in first when you insert it. On each end there is that silver metal circle that has some silver metal extensions that go straight across the bottom.
4. look into the flashlight toward the led end. See the green circular circuit board thing. You'll see that equally around that circular base, there are 4 little squares of metal right to the edge of the green base, equidistant around the green circle. Carefully insert the battery holder with the silver metal strip on the holder lined up so each end of that strip will touch one of the 4 little square metal things on the edge of the green circuit board. The goal is that when the battery holder is all the way in, the two metal extensions coming out from the little circular metal piece on the end of the battery holder will each touch one of the little square metal pieces on the green base.
5. Screw on the lid and click the end to turn on the light. I tried this two times and both times it worked. If it doesn't turn on you might want to try to reinsert it again and get it more carefully lined up.
Good luck.
Apr 28, 2013 | Emerson 9X Power LED Flashlight
The light would not go off
Sounds like another Bad switch.Common lately.
Jan 05, 2013 | Streamlight 61082 BuckMasters Trident...
The camera still works but when its dark in the room nothing shows on the monitor. If we turn the light on it works. It seems like the night vision feature is broken. I covered what looked like the light...
  1. It should go to automatic night vision. If this feature is not working then the answer to will a flashlight work the answer is not very well. The light will have to be on the child and a flashlight does not have much light behind it. Perhaps if you put a small lamp on a dresser that shines on the area the child is, this may work enough to keep an eye on him/her. A flashlight not so much. Hope this helps.
Regards, Tony
May 25, 2011 | Summer Infant Day Night Handheld Color...
How do you change batteries stanley 3 in 1 tripod led flashlight
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
Dec 08, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
The charge in my milli cancdle power light lastsat the most 3-5 m
Your problem is almost certainly a bad battery. The fact that it lights for 3 to 5 min after each recharge indicates that the charger is good, and the battery wont take or hold a charge. That is my guess. Batteries Inc stores carry these batteries and are very helpful they also have a website: www.batteries-inc.com
Oct 14, 2009 | Camping, Backpacking & Hiking
Have put new batteries in bulb is ok just stopped workin 5 cell dd batts
First of all are you certain the bulb is ok? Test for continuity across the light bulb. The filament in light bulb will have a very low resistance. if you are not handy with a multimeter then respond back with a new thread and I can give you more tips on using a multimeter.
Next, clean the contact surfaces off where the battery terminals contact the flashlight copper contacts. You can use a high grit sand paper if necessary. They sell battery terminal cleaner solutions/supplies at Automotive stores if you like. However, distilled water and/or alcohol will probably work just as good.
Next connecting one probe of your multimeter to the top inner contact and then the other probe of your multimeter to the lower inner contact turn off and on the switch. When the switch is on, you should see the same resistance that you checked the resistance of the light bulb filament.
If you don't see the same resistance then switch is bad.
If resistances are equal then place batteries back in flash light and everything should be good to go!
Aug 04, 2009 | MagLite Flashlight Type: Black D Cell 5:...
What is the button and set of 5 lights on a dell c610 battery for
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
Jan 27, 2009 | Dell Latitude D600 Notebook
Orange Coast LED Lenser LL7555 V8 Standard Torch bright  LED Keychain flashligh Logo
139 people viewed this question
Top Orange Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you an Orange Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
