Question about Philips Televison & Video
Red strip on right of screen - Philips Televison & Video
    President:
  • 1,284 Answers
If the line is only one pixel in width then the panel is bad. If the line is an inch in width or more then there is a possibility it is a bad data driver board. This issue should be looked at by a technician.
Posted on Nov 13, 2009
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
I've bought an adapter thing, but I don't understand how to wire these wires.
  • Yellow - To the car battery of continuous +12VDC
  • Red - To ACC Power, +12VDC
  • Black - Ground, to bare metal or clean part of the car
  • Dark Blue - Motor Relay control lead for Antenna
  • Dark Blue / White Strip - Amp Relay Control lead
  • White - Front/Left Positive Speaker
  • White / Black Strip - Front/Left Ground Speaker
  • Gray - Front/Right Positive Speaker
  • Gray / Black Strip - Front/Right Ground Speaker
  • Green - Rear/Left Ground Speaker
  • Green / Black Strip - Rear/Left Ground Speaker
  • Violet - Rear/Right Positive Speaker
  • Violet / Black Strip - Rear/Right Ground Speaker
Nov 11, 2010 | Panasonic CQ-DP133U CD Player
Uneven red color from left to right in the
you have a fried light filter on one of the lcd panels, due to excessive dust and heat. you will need to replace the entire optical engine, as epson does not sell individual pieces of it.
Nov 12, 2009 | Epson EMP-74L Multimedia Projector
Sound button is red on strip of hp pavilion dv
chk the volume control if thats ok try using a head phone which is working if it works then problem with speaker
Aug 12, 2009 | HP Pavilion dv6000z Notebook
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
3 inch red area at top of screen and smaller blue area at bottom of screen
this would need a optical block. there would be no other way to solve this issue
Apr 18, 2009 | Televison & Video
Wiring problem
grays are right channel and greens are left. The red stripe and large back stripe are for rear channels.
Apr 14, 2009 | Car Audio & Video
I have a red strip about a a wide all the way down the screen
It sounds as if your display is going bad. If put a little pressure on the screen and the red strip warps it is probably your liquid crystal display in the screen itself.
Apr 03, 2009 | Dell Inspiron 1501 Notebook
Vertical lines in my laptop screen
Have you tried hooking it up to an external monitor?
This would ensure that it's the screen and not the video card..
If you do that and you receive a good picture then it could be something as simple as a loose video cable. Or it could also mean something like a bad video card or the expensive one, a bad screen.
Mar 08, 2009 | HP Pavilion dv8000t Notebook
Televison & Video Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
