Question about Epson Office Equipment & Supplies
I have an epson cx7400 all in one printer. i need to know how to take it apart because there is an internal paper jam and my warranty is expired
  • 3 Answers
When i try to print nothing works
Posted on Feb 11, 2010
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
Paper jam light keeps flashing, but no paper jam can be seen. Won't print .`
Open your printer paper feeder. Then look inside it. There is plastic roll inside it. That is the curlprite. Try to open it. at the last stage you may see a spring that usually is in the plustic rollar's holle. Remove it and re assemble carefully. That's ok.
I think you will be relive from your printer problem.
Thank you.
Jun 15, 2011 | Epson Stylus CX7400 AllinOne InkJet...
I need to restore the software for my Epson Stylus CX7000f PRINTER in my new computer. I can not find the original disk, from where can download the software
The Epson Stylus CX7400 Color All-in-One printer prints up to 28 pages per minute of black ... Stylus CX7400 ink jet all-in-one, 69 black ink cartridge (T069120), ... Best of all, you don't need to wait for an available computer to get started. .... Also, given my experience, one paper jam can cause your printer to ...
www.amazon.com/Epson-Stylus-CX7400-Printer.../B000SDXZX8
Jul 16, 2010 | Epson Stylus CX7400 AllinOne InkJet...
Epson workforce 600 continue to get paper jam error and there is no paper jam..
If this message appears when you turn the printer on it will need a repair, this will be down to a sensor fault.
If this message appears when you try to print Check you are using the correct paper type and size settings, on the printer if being used standalone or via the printer driver if using via a computer.
Also try using a different paper type and brand ideally Epson paper as it is an Epson printer. If the fault continues the printer will need a service.
As this printer was released this year you should be covered by some form of warranty, contact Epson for a service.
Dec 13, 2009 | Epson WorkForce 600 All-In-One InkJet...
I do not have the disk that came with my Epson Stylus CX7400 and I cannot install it. What do I do??
You can download the software and drivers at the Epsom website for Stylus CX7400.
These links give you all the software you will need - select drivers and utilities combo package for your operating system.
Windows
Mac
Overview, troubleshooting and links for CX700
Documents and Manuals including installation guide
Hope that helps you :)
Nov 18, 2009 | Office Equipment & Supplies
Whats going on with my printer
Replace paper feeder. Or find at aicaxz solutions about fixing paper jam without replacing.
Sep 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus CX7400 won't feed/load any type/size of paper
You may have gear, roller problems. Try the head alignment process, if need be call Epson tech support. Epsons are really cheap if you need a printer. If you are going to buy a printer then Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 23, 2009 | Epson Office Equipment & Supplies
Paper jam
Usually paper jam error message on this machine is either caused by a physical paper jam or a printer error. To distinguish between the two I understand that you have already checked with the printer if there any paper or foreign object but there is none however, just to make sure you have checked everything out, check the left the side to double check. Now there is really nothing that you can see I really means that it is a printer error and that you would need to contact Epson directly to get a replacement. I do not recommend tearing off the printer because that's voids your one-year manufacturers warranty.
Jul 14, 2008 | Epson Stylus CX9400 Photo Printer
Paper jam
Pape jams is caused by either a physical jam or an unknown printer error to determine which one is it follow this steps.
1.If it just came out of the box make sure that before you turn it on of connect to the computer that all tapes has been removed and no foreign objects is within the printer when you lift up the scanner part of the unit.
2. It may not make sense but one of the common mistakes is that the left side of the printer is not being check throughly I would like you to double-check in the area.
3. Lastly, if you really don't see anything that maybe cause this error message unfortunately, I would recommend that you contact Epson or the place where you have purchased it to get a replacement. Its not advisable that you tear apart the printer becuase that woukd void the manufacturer's one-year warranty.
Jun 01, 2008 | Epson Stylus CX9400 Photo Printer
193 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
