Question about GE WSXH208A Front Load Washer
HOW DOES THE DRAWER TO MY PEDESTAL BASE MODEL SBSD137H5WW , SERIAL NO. HR124045G COME OUT SO I CAN SECURE THE SCREWS AT THE BACK INTO THE WASHER AT THE TIME OF INSTALLATION? MY WASHER IS A GE MODEL GRVH5300K0WW
Went back to Lowes to talk to a sales personal. He informed me that there are two screws at the front of the drawer (one per side) After removing these screws (you will need to put them back after) the drawer will be removable from the pedestal base.
Posted on Nov 15, 2009
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Need to remove the drawer from the pedestal
Two screws is all that needs to be removed. These screws have a nut so you will need a wrench. The screws are located at the front of the metal rail that the drawer rides on. Empty the drawer, remove the screws and slightly lift and pull the drawer free.
If you are having a problem with the door staying shut like I did the part responsible is the little white square box called a 'Latch' located at the front bottom of the casing, in the middle held by two screws. A black 'strike' on the door inserts into this Latch. If the strike is good the latch should be the problem.
Strike Part Number: 137006900
Latch Part Number: 137006200
Here is a web page with a break down of the parts: http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/All-Products-Parts/Model-EPWD15RR2/1412/0153050/R1007111/00001
Hoping the web page isn't against any rules, if so I'm sorry...
Nov 20, 2010 | Electrolux 15 Silver Sands Pedestal...
Installing pedestal to washer
You want to level just the pedestal in the place where you will be using it so when you put it in position mounted together later it is done. Also very easy to do first. Get the pedestal level, tighten the lock nuts, put the washer on its back. Usually you remove the washer feet, take the pedestal drawer out, screw on each side, bolt the pedestal to the washer with the four screws provided. Tip pedestal and washer up, on to something that slides easily to protect floor. There usually are some type of shipping bolts that have to be removed from back of washer before using on new units. Usually four and these have to be removed.
Jan 13, 2010 | Maytag EPIC MFW9700S Front Load Washer
How to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
Jan 01, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
How can I remove the Whirlpool Duet washer pedestal drawer?
When you look this will not appear to be how it is done but it is in fact the way. Pull the drawer all the way out and then look on the side of the drawer at the very front and you will see a single small screw that attaches the track to the drawer. It would appear this is part of a series of screws and the track itself should seperate but neither side of the track removes. Simply remove these screws on both sides of the drawer with a small hex head socket and the drawer will pull right out. Push the tracks back into the pedestal until done cleaning the drawer.
Jun 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is off balance. Need to get to levelers.
I had the same problem...thanks for posting a solution. I agree with the solution posted above, but on my unit they are 1/4" HEX head screws, not phillips. Look at the illustration on page 4 here for help:
http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/XHP1550VB_Installation%20Instruction.pdf
I hope that helps.....
Dec 30, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Replacement kenmore pedestal front drawer cover?
The pedestal should have it's own model number on it. Find the model number and contact Kenmore parts depot and they should be able to get you a front panel.
Dec 26, 2008 | Kenmore 15.5 in. Pedestal
Attach pedastal to whirpool duet washing machine front loader
you will want to lay the duet unit on its back. remove the legs. put the base up to the bottom of the duet. you can use the legs as bolts and pass them thru the top of the base back into the bottom of the duet appliance, using them as bolts. I have had some people just get new bolts. this should fix you up. please rate this if it was any help.
Thanks,
David
Oct 11, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Samsung Pedestal Drawer
If you pull out the drawer (completely) you should find 1 or 2 screws on each side that bolts the slider to the drawer. Remove these, then lift out the drawer. This then gives you full access inside. ...JimS
Jul 31, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Remove pedestal drawer from washer
First remove the top of the washer via 3 tork, 7mm hex head screws (they are hidden located on rear of washer) then you can see to line up the tub with the shipping bolts. Just put 2 in --one lower and upper opposing each other and that will be sufficient. I believe there is two screws holding the drawer in located at the track towards the front of the drawer. Now you can lean it over with no worries to remove pedestal
Jan 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE WSXH208A Front Load Washer Logo
343 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
