Tv repair the power will not stay on.
  • cob139 Jan 08, 2008
    the power on my tv will not stay on?
    Novelist:
    Champion:
  • 254 Answers
You don't give much in the way of details... How long does it stay on? Long enough to give a picture and audio?? Or maybe 10- 30 minutes?
If it only comes on momentarily, not even long enough to give video, then it could be going into Hi-voltage shutdown, probably indicating an overvoltage condition. This could be caused by a voltage regulator failure. Troubleshooting this is best done by a qualified technician.
If it stays on for several minutes, maybe even 30 minutes or so, then goes off, bad solder connections might be the culprit. A modest whack or bump on the side or back of set might confirm this. Whack it... if set dies, you likely have a bad connection problem. If you have good eyes, a solder iron and solder, and know how to solder, then you might be able to find the bad connection(s) on the chassis. Common locations for this are in the horizontal deflection, power supply or vertical deflection portions of the circuit.
Posted on Jan 08, 2008
The sound and picture goes out on my LG lcd tv. Power light stays on
if you are not a tech then take your tv to a repair man.there is a problem in your tv power supply...the pwer supply is attached to where the power cord leads to the wall outlet.good luck.kindly dont make repairs yourself.
Sep 23, 2011 | LG Televison & Video
When I turn my tv on, it takes any where from 7 to 15 times before it will stay on. When it shuts itself off, the amber light blinks one long blink and six short blinks... don't know if that could be an...
It sounds like the power supply is having issues, the main relay may be malfunctioning and not staying on until it starts to warm up. If your TV is still under warranty I would definitely use that. If not, power supplies are repairable at most local TV/Electronics repair shops. it may cost you $100-$250 to get it repaired though.
Mar 10, 2011 | RCA L32HD31 32 in. LCD HDTV
Tv would not stay on
It could be bad power supply board or bad inverter board or bad screen. Repair shop or buy new one- depends on how old the tv.
Mar 02, 2009 | Envision Monitors L26W661 26 in. LCD TV
TV Repair Discovery
It is possible that it is due to the power supply since you said "I can turn the TV off with the remote, but can't turn it on again unless toggle the power switch off (and then on) the set itself and only then can I use the remote to turn the TV on"
The power supply could be failing which could cause that symptom. Otherwise if it was not the Power supply it would likely be the main video board that is failing. In any case I would probably take a look at the power supply first as it seems to be a common fail point of the Akai LCT2715.
If it is the power supply you can have it replaced by a TV repair service. They usually do not bother repairing them which ends up 1) costing you more 2) being unnecessary. I offer to repair these Power Supplies if they are indeed faulty. I charge $100 + Return Shipping for the repair.
Oct 13, 2008 | Akai LCT2715 27 in. LCD Television
POWER DOES NOT STAY ON...PLZ HELP
Hello carriegomez,
It sounds like you shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jul 09, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Power will not stay on. ? Lightning.
Hello, it is hard to say if this would be a costly repair without making an apropriate diagnostic of a specialized technician. Best regards, Arpi
Jul 26, 2007 | Mitsubishi VS-45609 TV
TV will not stay on
Greetings from Belize take your set to a tech for repairs if you have not done so.your are having problems in your power supply section or your horizontal circuit.good luck.
Dec 31, 2006 | Toshiba MD14F11 TV
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
