Question about Porter Cable Air Tools & Compressors
I have a Porter Cable pancake compressor 135 PSI 5.3 scfm 1.6 hp running. The gauges do not show any charge and the tank doesn't hold any significant amount of air. What could the problem be? I need to know so I can decide if it is worth repairing or should be deep sixed.
  • 520 Answers
Could be a leak at the bleeder valve. That's usually the problem I find. They get beat and banged around. Then they start to leak. Hope this helps. Good luck.
Posted on Nov 13, 2009
Why will my bostitch pancake compressor 240 psi tank 180 regulator that the guages will not show building pressure
Hi, There are different posibilities. I would need more information. Was it always like that? Does the guage on the main tank and the guage on the regulator both not show more than 20psi? When the auto shut-off is triggered do you feel there is more than 20 psi in the tank?
Sep 15, 2014 | Stanley NEW Bostitch 2 HP 6 Gallon...
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
Porter Cable pancake rated at 150 PSI stops at 135 PSI. It has done this since it was new.
If it's pumping up to 135 psi, shutting off and then restarts at the same pressure point since it was new, the pressure switch may have been set low at the factory. I don't know which model you have but most pressure switches have directions inside their cover as to how to adjust the cut-out and cut-in pressures. Be careful doing this, overpressuring the tank is dangerous. There is an adjustment screw or bolt that changes the pressure on the switch spring. Some pressure switches have two screws, one for cut-in and one for cut-out pressure. A few have one that adjust both pressures. If you do adjust the cut-in/cut-out levels, do it slowly and cycle the motor a couple times between each adjustment to see where it turns off and on. If the compressor is doing what you want it to, only pumping to 135 psi, it will live longer than if you adjust it up to 150 psi. Those last 15 psi of air are hard to get and will mean the motor will be running longer and more heat will be building up in the head.
Oct 01, 2012 | Porter Cable Air Tools & Compressors
A porter cable 135 psi 60 gallon upright
If the motor doesn't shut off at the desired pressure then your pressure switch is either set too high or is broken/stuck. The pressure leak at 150 psi is the safety valve doing its job opening when the pressure gets to an unsafe level in the tank.
Aug 27, 2012 | Porter Cable Air Tools & Compressors
I have a porter cable 6 gallon compressor. The motor used to cut out at 150 psi, but now it cuts out at 135. Is this a faulty tank pressure gauge misreading the pressure or a motor cutting out too early
it could be your air pressure adjustment knob, where your air line hooks up, which controls the psi to a lower or highist seting to adjust for different tools and uses.
Aug 26, 2012 | Porter Cable C2002 6 Gallon 2 Compressor
Need Manual for Husky Model 41214 Air Compressor
You can get the manual for model 41214 from my dropbox area:
http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
http://db.tt/vQycqXIW
Thanks,K
Dec 20, 2009 | Air Tools & Compressors
Won't start -Porter Cable Cable 135 PSI, 60 Gal compressor
ARE THE POINTS BURNT IN THE PRESSURE SWITCH? DO YOU HAVE A LEVER ON THE SWITCH SET TO ON OR AUTO? IF YOU THINK ITS THE SWITCH JUST BYPASS IT AND TIE THE WIRES TOGETHER TO SEE IF IT RUNS. BEWARE YOU HAVE NO PRESSURE PROTECTION EXCEPT POP-OFF VALVE. MOST P.O.S. COMPRESSORS LIKE PORTER CABLE HAVE 3500 RPM MOTORS AND HAVE A THERMAL RELEIF BUTTON ON THEM. JUST PUSH TO RESET. MAKE SURE YOUR WIRNG OR DROPCORD IS LARGE ENOUGH GAUGE. SMALL GAUGE DROPCORDS KILL COMPRESSORS.
Jan 17, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Air Tools & Compressors Logo
129 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
