Bosch Exxcel WVT1260 On drying the heater seems
On drying the heater seems to be working but the clothes are not drying & there is a lot of hot water vapour when the door is opened.
Comments please.
  • 68 Answers
Check your venting. If the water vapor can't get all the way outside, your dry times will be longer than usual and the steam will come out the front when you open the door. You may need to clean your ducting, which is a good idea anyway to reduce fire risk.
Posted on Nov 14, 2009
My Bosch classix dryer is not drying the clothes. The drum is turning & it feels very hot on the inside & on the outside of the machine. There is a lot of condensation around the edges & where...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 11, 2011 | Audiovox Bosch 718 World Cellular Phone
My bosch sgs45 tripped the electrics out, now the machine washes the dishes, but does not get hot and stays washing on 1 indefinatley,i have checked the pipe under the kick board which was blocked,also the...
and have you checked the heater element for continuity? also check to where the wires are connected to the element as well sounds like a short to me Thanks Rick
Apr 10, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
The machine does not heat up
Bosch dishwashers do not have a heated dry option, the water is heated with a inline water heater but it does not have a heating element to dry the dishes. Make sure that you use jet dry and that you open the door when it is done, after an hour or so the dishes will be dry. This is a common issue with the Bosch dishwasher, but not a problem with the unit
Jan 05, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
My Bosch Classixx washer dryer has stopped drying and the clothes come out steaming hot and steam escapes from the powder drawer during the drying cycle. I have had an engineer out and he says the airflow...
if you have a very large load of clothes in the machine on the dry cycle, what tends to happen is that the clothes are not flapping around in the drum loosely but they are going around the drum in a big mass, with the result that they just get very very hot and steam will escape out the soapbox draw. When this happens, heater unit that becomes overheated ant the thermostats will eventualy cut out resulting in cold air being circulated instead of hot. You will need to have them replaced again. when replaced, put on a drycycle with only a few garments in the machine and you will see a big difference in it perfomance. washer/dryers are not very effective on the drying cycles with a full washload.
if you need any more help, you may email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Bosch Classixx WVF 2402 Front Load...
Not drying correctly leaving residue on clothes
its uncommon for elect dryer to put res on clothes your vent must be stopped up
Nov 17, 2009 | Bosch Exxcel WVT3250 Front Load Washer /...
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Drying cycle working but not drying clothes
First clean filter for lint - next be sure the temp sensor at blower if free of lint - next, in the heater contrl unit, two solinods contrl the heating process - I hope it's the first two ideas - Try it - Good luck
Oct 15, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Dishes still wet
You need a new heater element . Get engineer to fit for you.Cheers,Derek.
May 19, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch exxcel wvt1260
I have a Haire combo unit. (washer/dryer) The dryer is a condenser type. I had a this problem with the dryer part of my unit. It was still under warranty at the time so naturally I called. When the tech came out he discovered that the heating element had melted the fan all over the blower elements. this problem could have been fixed, however, Haire came out with a newer model and couldn't get the parts anymore because they weren't making them anymore. Needless to say that totally sucked. But, at least the washer still works great. Upon doing a little research, I discovered that most condenser dryers do get too hot to support one or more of thier internal elements. I would not get another dryer like this without asking about this problem and if there has been any rectification of this issue and how so.
Jun 23, 2007 | Bosch Exxcel WVT 2850 Front Load Washer /...
Washing Machines Logo
451 people viewed this question
Top Washing Machines Experts
