Question about Garden
How to replace fuel line/filter 1994 husqvarna 36 chainsaw?
Does anyone know where i can find a diagram or video that shows how to install a new fuel line in a 1995 husqvarna 36
    President:
  • 2,220 Answers
You can find an IPL with fuel system components, part numbers and some detail here: They are probably spread overr multiple images.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
typical fuel system:
how to replace fuel line/filter 1994 husqvarna 36  - 9497aa6.gif
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Posted on Nov 13, 2009
Sass
Starts but stalls when hot. Chain is not too tight
Larry,Carburetor may be dirty, remove and clean or rebuild. Check the attached links,videos,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna Chainsaw 235Troubleshooting Repair Help
How to Troubleshoot Husqvarna Chainsaw Problems eHow
Husqvarna 136 Chainsaw Carburetor Rebuild Fuel Line Repair
http://www.mymowerparts.com/pdf/Husqvarna-Service-Repair-Manuals/W9200002.pdf
Apr 19, 2016 | Husqvarna Chain Saw Models 51, 55
How do you replace fuel line on Husqvarna 455
You will need to pull the fuel line out of the fuel filler hole. Remove the fuel filter. Pull the line out of the tank. When re-installing the line cut the end at an angle to allow you to push it back through the hole (it is tight). Reconnect the filter. Then attach to carb.
Aug 21, 2014 | Husqvarna Garden
HUSQVARNA 41 CORRECT FUEL FILTER TO BIG FOR MY FUEL LINE IN TANK--DO I NEED TO GET BIGGER FUEL LINE??
you can get saw specific parts from a Husq. dealer or you can make shift something to get you by. the key is to make sure the hole in the tank is slightly smaller then the diameter of the hose to ensure there is no air leak there. I drill the tank hole out a size at a time until I have to force the hose in that will fit snuggly on the carb inlet then replace the fuel filter with one that fits the line
Mar 20, 2013 | Husqvarna 36 41 50 51 55 136 141 154 254...
Husqvarna 36 cc chainsaw wont start replaced spark plug cleaned carb
Are you getting a spark..? - NO? check wiring loom from ignition module, check timing gap between flywheel and ignition module, check on/off switch.
Does it have compression.? - NO? then check piston/rings and cylinder
Is fuel getting to the cylinder.? - NO? Carb problem of fuel line issue
Dec 06, 2012 | Husqvarna Garden
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I have a Husqvarna model 444 chain saw. The fuel pick up line disolved in the fuel tank. How do I replace?
order new fuel line and filter from www.randysenginerepair.biz
remove top cover, remove air filter, remove fuel line from carburetor, empty gas tank, pull remains of fuel line out of tank and replace with new.
Aug 25, 2010 | Husqvarna Chain Saw 20" Bar
How to replace the Husqvarna chainsaw fuel line.
let me knoe the model number and i'll see what i have....
Oct 29, 2008 | Garden
Husqvarna chainsaw repair
Usually empty fuel, use hook to pull out line , remove filter. Remove air filter cover and airfilter ,now you should be able to see line. Most just pull of carby and go through tank, some you may have to take screws out of av mounts in back of tank to see hole to put it back in.cheers hope this helps if where a stihl i could tell exactly.
Oct 29, 2008 | Husqvarna Husky 165
Fuel line replacement
I recommend remove all fuel from the tank. Remove the hose from tank to carb. take the tube with you, when getting new hose.
Oct 09, 2008 | Husqvarna Garden
Garden Logo
705 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
